finally! Revup Vortech Sedan tuned
Old 05-11-2015, 03:34 PM
usingthejohn
usingthejohn's Avatar
Default finally! Revup Vortech Sedan tuned
Took a long time to finish, but I'm happy and excited to say it's finally tuned!!
I've never done any work on a car before this, so this was definitely a learning experience. Originally, I bought the kit as a nonrevup, but converted it to a revup. Being I've never owned an FI'd car before, I'm definitely pleased with it so far.
Car: 2005 Revup G35 sedan
Non-revup to Revup Vortech V2
3.12 pulley
600cc deatschwerks injectors
Ngk 1 step colder plugs
PMAS MAF
Walbro 255lph
Uprev, tuned at Church Automotive
Megan test pipes
Motordyne XYZ and full exhaust
Volk TE37 19x8.5/9.5 +22 with Toyo R888 245/35/19 and 255/35/19
Wilwood BBK front/rear
Innovative wideband A/F and dual oil temp/pressure gauge
OEM flywheel and clutch
There's still some things I want to do, but in the immediate future I need to buy a clutch/flywheel and an oil cooler. I also have a set of Evo X Recaros I got from my friend for real cheap that I'll be installing soon.
Sorry, no photos yet. I'm still at Churchs but couldn't wait to post!
Old 05-11-2015, 05:23 PM
usingthejohn
Here's the dynapack printout.
Old 05-11-2015, 06:05 PM
OldManZ350
OldManZ350's Avatar
Very Nice.
Old 05-11-2015, 09:09 PM
studbolt03
studbolt03's Avatar
Nice !!! Have any of the non rev up parts??? I need a few lol.
Old 05-12-2015, 10:46 AM
Resmarted
Resmarted's Avatar
I have a non rev up lower plenum sitting around if you're interested
Old 05-12-2015, 11:40 AM
meanz
meanz's Avatar
Nice, what kind of boost are you seeing with the 3.12?
Old 05-12-2015, 11:51 AM
usingthejohn
Looking at dyno sheet, I was seeing 9.3psi
Old 05-14-2015, 11:32 AM
NAbuilderZ33
NAbuilderZ33's Avatar
Nice numbers! Nice combination of parts also!
Old 05-20-2015, 07:54 PM
philthethrill
philthethrill's Avatar
nice i just finished building a 06 rev up sedan. waiting on tune . nice build
Old 05-20-2015, 07:57 PM
philthethrill
what blower do you have ? i know its a v2 but is it sc si?
Old 06-10-2015, 11:32 PM
usingthejohn
Just some photos to insert. Here's the wheels I'm picking up Friday. Not my photo, however that's the color I chose. I picked up a second set of TE37S to replace my current ones. Then I'll be selling the silver ones
Here's the seats I'm installing this weekend.
And here's how she sits now. The lip is scratched to hell from neglect and carelessness. No matter, as I'm taking it to the body shop next week, since some idiot backed into me in a drive thru.
Edit:
Found the actual photo i received from the Powdercoating shop
Old 04-23-2017, 12:14 PM
usingthejohn
So I'm bumping this thread from the dead. Been two years since I got it tuned and it's still running fine. Haven't done much to it since; just did a low beam projector retrofit and picked up an ARC oil cooler off a part out.
Additionally, picked up a low mileage long block off the local marketplace and plan on building this on the side. Not planning on crazy numbers. Just a 2.87 pulley and a Ti Trim blower. Although there isn't as much activity on the boards anymore, I still really enjoy my car. And it only has 59K miles on the odometer.
Old 04-24-2017, 05:00 AM
Highway Riding
Highway Riding's Avatar
Nice update! This is dope.. Cheers
usingthejohn (04-28-2017)
Old 04-27-2017, 01:50 PM
philthethrill
wi got a 2.87 and ti in my sedan made 580 500
Old 04-28-2017, 05:11 PM
usingthejohn
Did you go with an IPP-build block? What compression ratio did you go with and are you on E85 or pump?
I'm planning on just 91 octane. That being said, I was talking with a friend of mine and I may end up just doing a 928 rebuild along with the 2.87 pulley. I don't need crazy power.
Old 04-29-2017, 07:47 AM
philthethrill
Built block, no cams witch sucks cuz id habe picked up like extra 100whp. Its choking up top. Im on e85 ti blower..with my engine i should have just kept the si and maxed it out. Without cams and head work you cant get the most out of the ti. I made max power at 17psi but i made 21 lbs total.
philthethrill
Im 10.1 bit if i were you id do 11.1
Old 05-11-2017, 06:33 PM
usingthejohn
Picked up an ARC V2 catch can. I've been doing tons of searches and can't seem to find the consensus on how to run the catch can with a Vortech. Does anyone have an idea on how to run it? I don't want to start another thread for this seemingly simple topic.
Old 05-15-2017, 04:43 PM
philthethrill
i have a line in the manifold under the intake and the other is in the elbow i have coming off my supercharger. Im actually wanting to change it up to the pcv valce and valve cover on passenger side but for know it works.
2ndchanceZ
10-26-2015 08:03 PM
350z82
10-01-2015 06:25 PM
KOF
Tuning
09-30-2015 04:09 AM
Quick Reply: finally! Revup Vortech Sedan tuned
