Another Daily Driven Vortech Build
Old 12-06-2017, 09:59 AM
  #221
Staisman
Staisman's Avatar
Why did you decide to go with 2000CC injectors? It is hard to tune 2000CC and that's why you have rough idle. I am pushing well over 500 whp with E85 on 1000CC injectors with no problems. My idle feels like stock. Also 85% duty cycle is better than 50%.
Old 12-06-2017, 10:22 AM
  #222
BluestreamDE
BluestreamDE's Avatar
Because I plan to upgrade the blower eventually and didn't want to pay twice for injectors. I want to get the heavy duty V2 Ti trim. Idle is a little better. The reason for the rough idle I figured out is that these injector minimum time needed to spray is 1.30ms, so if there is not enough power going to the injector based on what the maf is reading, they just shut off.
My fix was higher idle at 1250rpm and a richer idle target (.95 lambda/14.0afr) which the maf sensor sees enough airflow to keep the injectors pulsing. Idle is fine and hot/cold starting is fine, no issues.
Yes, my numbers are literally with 13°-15° timing, I'm running 19° now so I am for sure making more than 500, and I still have more to go. I would like to see how close I can get to you in power with the same pulley setup but ultimately the end game is to upgrade the blower next year and it doesn't make sense to buy injectors twice imho.
Old 12-23-2017, 04:54 PM
  #223
BluestreamDE
No updates atm, was supposed to get on the rollers earlier this month but I'm on vacation. Plans for the first part of next year is to get the Treadstone TR1245, run a velocity stack at the blower to get better airflow and possible gain some more boost, and retune with e85 again. Then later on, sell my V3 and purchase a V2 Ti Trim round the summertime.
Old 01-21-2018, 08:35 AM
  #224
Chinky4U
Chinky4U's Avatar
From the looks of it, I should just skip the V3 and go straight V2 TI trim lol.
Old 01-22-2018, 10:16 AM
  #225
BluestreamDE
If you built your motor already, l would go for it if you can. I'm just working with what I have till I upgrade.
Old 02-02-2018, 10:56 AM
  #226
JaE35z
JaE35z's Avatar
Love the build...got mine on and just need to get it to the tuner...does the car drive okay if I take the rear cog belt off? I've quite a ways to go and don't want to damage anything with the oil feed and all hooked up
Old 02-02-2018, 02:21 PM
  #227
BluestreamDE
Yup, just take the rear Cog belt off and you will drive like NA. Or just drive carefully and not go into boost or heavy throttle driving.
Good luck on the tune!
JaE35z (02-07-2018)
Old 02-24-2018, 05:01 PM
  #228
BluestreamDE
Somewhat of an update on the Z. Haven't really been buying parts, just tweaking my tune here and there. I am moving to South Carolina for my new Duty station in about a month, and also purchasing a new home for my family there, so all my focus is on prepping to leave Texas unfortunately. Good news is there is a lot of reputable shops around that part of the country, Dynosty, Z1 to name a few, within driving distance.
I know I said I wanted to upgrade to the Ti trim blower and retire my V3, but I am currently now looking for a V7 YSi now and plan on getting CJM Twin Pump. I still plan to use E85 as my fuel of choice. I'll be sure to update on here when I start buying everything.
BigBlue (02-24-2018)
Old 02-24-2018, 05:43 PM
  #229
BigBlue
BigBlue's Avatar
Sounds great Bluestream! I look forward to seeing what you ended up doing.
BluestreamDE (02-24-2018)
Old 02-24-2018, 05:51 PM
  #230
BluestreamDE
Thx brother, yea life/work unfortunately comes first before play.
Old 02-24-2018, 06:26 PM
  #231
2bad240
2bad240's Avatar
What part of SC you moving to
Old 02-24-2018, 06:32 PM
  #232
BluestreamDE
Sumpter County, where Shaw AFB is.
terrasmak (02-24-2018)
Old 02-24-2018, 06:53 PM
  #233
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
Don’t think I ever caught your in the AF. 13 April is my retirement ceremony, got to figure out when to do when I grow up.
Old 02-24-2018, 06:58 PM
  #234
BluestreamDE
I am not airforce, I work with them in my MOS but I am Army. I'll be with Third Army (ARCENT) there.
Congrats on your retirement!
Old 03-06-2018, 08:22 PM
  #235
BluestreamDE
Welp, I work fast. With everything going on with preperations to move, I was able to get a sweet deal on a V7 YSi Supercharger Kit + a TR1245 from a-town204 here on the forum for a killer deal! The kit will be shipped out to me by the end of the week. All I need is the CJM Twin Pump and I will hopefully be set for more power in the later months after moving to SC.
BigBlue (03-07-2018)
Old 03-09-2018, 10:58 AM
  #236
OldManZ350
OldManZ350's Avatar
If you are running e85 you will need a CJM 255/485 Twin
Old 03-09-2018, 01:39 PM
  #237
BluestreamDE
Yes I am already aware. Thanks Oldman.
Old 03-16-2018, 06:54 PM
  #238
BluestreamDE
YSi kit came in today. Will take more pictures tomorrow and upload. The piping is all 3 inch and came with a custom intake with a filter I will replace with one that flows better. Impeller spun freely with no issues.
BigBlue (03-16-2018)
Old 03-16-2018, 07:10 PM
  #239
BigBlue
BigBlue's Avatar
Congratulations Bluestream! I really look forward to seeing the pics and hearing your review of that awesome system; will be a street beast.
BluestreamDE (03-17-2018)
Old 03-17-2018, 05:41 AM
  #240
BluestreamDE
This is the entire kit with all pipes, bolts, couplers, pulleys, some Timrod Strut Brace pieces, Treadstone 1245 intercooler welded with the front crash bar. Came with a Tial BOV as well, the same one I run currently with my V3.
Some things that need to be addressed: New Air filter that will flow more air than the one currently installed, Pulleys on the mounting bracket have normal amount of belt residue that needs to be cleaned off, and I need to figure out the layout of the Timrod Brace and how to properly install it. Also since this is an engine oil fed blower, I will need to tap my oil pan in preperations for it to be installed.
Other than that, this is a pretty good kit, as I stated in the last post the impeller and blower spins and operates normally with no odd noises and no apparent volume contact. Very happy with it.
BigBlue (03-17-2018)
