FI bug has bit, going Vortech
Old May 5, 2016 | 09:26 PM
  #81
terrasmak's Avatar
The turbo kit dies have a cracked manifold, I can get a set of new manifolds with it. How well have the repaired Greddy cast manifolds held up, or should I just get the new manifolds.
Old May 5, 2016 | 10:33 PM
  #82
Justin100's Avatar
Justin100
greddy cast manifolds are known to crack.....
did you buy this kit off of b_hoss?
when i saw that guys ad I would not have bought his kit. their is too much involved with fixing all the problems with his stuff.......
its already bad enough to buy a used turbo kit but to buy a used turbo kit that needs to be fixed is more hassle than anything else.
if you were to rebuild the kit to something somewhat usable you will have more possible problems in the future for the other items to wear down......
Old May 5, 2016 | 11:51 PM
  #83
dikspiel's Avatar
dikspiel
Chestons Toilet
I wouldnt cheap out and fix a cracked manifold. I've learned the hard way cutting corners will end up costing you more.
Old May 6, 2016 | 12:19 AM
  #84
tcode's Avatar
tcode
Originally Posted by rcdash
This is a very old version of a base map. This is 1.04. We are on 1.13 now... The latest firmware publically released I think is 1.13.0
Actually, it's 1.13.02..
http://www.haltech.com/downloads-2/e...ware-firmware/
Old May 6, 2016 | 04:26 PM
  #85
Resmarted's Avatar
Resmarted
Get new ones 100%
Old May 8, 2016 | 02:05 AM
  #86
Cux350z's Avatar
Cux350z
hatersgonnahate
theres a few things you can do to prevent cracks.
1. When you install, make sure the passenger side turbo and pipe are away from the false firewall. Engine Tq and rebound can cause the turbo to contact the body.
2. Go solid motor mounts if you haven't already. They are not bad in the 350z.
3. support your exhaust. A lot of members buy downpipes that do not bolt to the tranny which leaves the nearest hangars at the rear of the car and the connection at the turbo. I used some hangars at the driveshaft loop cross bar to support...rubber mounted for flex.
4. Flex pipes in your y pipe
5. light weight exhaust if you don't do number 3 above. Not SS..its heavy. Go titanium.
You can weld Cast iron back together. The welder needs to know what he is doing.
Pre heat, grind out, short weld and proper rod and you'll be good to go.
Old May 8, 2016 | 03:17 PM
  #87
terrasmak's Avatar
I have fresh Z1 poly mounts , and was planning on a set of Berk down pipes. I know they are braced. I just have to find the trans mount. Then I was going to run my current Motordyne single with XYZ pipe.
I could also give the false firewall I few love taps with a BFH while the motor is out for extra clearance if needed.
Old May 8, 2016 | 04:46 PM
  #88
Resmarted's Avatar
Resmarted
If you have a trusted welder, it should not be a problem. But I have seen far too many crap "welders" who take a pretty penny. Cast is totally something a good welder can do. So is titanium. But how many welders out there actually will do it right?
You do NOT want to have to fix that manifold again 6 months from now.
If you were local to me, I know a guy who would slay that manifold for you. But, if you don't know for sure a great welder... I wouldn't bother. Not sure how much the manifold costs from greddy, but it would probably be worth just replacing in the off chance you get a bad weld. If you don't know what to look for, you could easily get something that seems nice, but has pinholes that are just going to leak etc.
Do it right, not twice.
Old May 8, 2016 | 05:21 PM
  #89
Cux350z's Avatar
Cux350z
hatersgonnahate
supposedly Qwik Crew Motorsports on FB can get them for 700 still. There are 2 people trying to make tubular renditions
You are correct at the welder. I would pick someone with EXP..not a first timer. Also, if the crack is too severe to where it cannot be ground out without making 2 pieces then it may be scrap.
poly mounts will help but a BFH will help more. I could see where a used turbo housing had be rubbing on the body, polishes a spot of paint off.
Ill try to upload a pic of my exhaust hangars. Nothing pretty. My AAM dp are not braced to the tranny.
Old May 21, 2016 | 08:14 PM
  #90
terrasmak's Avatar
Well the 18g kit I was getting, the owner decided to keep it for now. Back in the hunt for another or something comparable.
Old May 21, 2016 | 09:23 PM
  #91
bealljk's Avatar
bealljk
^WTF?
Old May 22, 2016 | 04:47 AM
  #92
yosip1115's Avatar
yosip1115
Also Ralph Has one too!
Old May 22, 2016 | 05:43 AM
  #93
Cux350z's Avatar
Cux350z
hatersgonnahate
just say no to internal wastegated turbos
Old May 22, 2016 | 05:47 AM
  #94
Cux350z's Avatar
Cux350z
hatersgonnahate
There is nothing special about the greddy cast iron or fixing it. It can be done by brazing or a TIG. The actual "welding" portion is the easy part...its all the prep prior to welding. The thing about fixing a crack in cast iron is to find it early, fix it right (grinding, drilling, cooling, preheating ect). Waiting until the manifold is in pieces is not the route to go.
There is a set of tubi manifolds in development but they will be pricey and if they do not provide any gains/flow then it will be hard to make the switch.
Old Dec 17, 2016 | 09:07 PM
  #95
terrasmak's Avatar
Back to this, died out , bought a new house , time to get back to this. Found a vortech V3 kit, time to get going.
Old Dec 18, 2016 | 06:21 AM
  #96
BluestreamDE's Avatar
BluestreamDE
Congrats on the new home! Vortech is alot easier to install and you get to keep your exhaust setup the way it is now, it will just be louder under boost. I installed mine in about 4 hrs taking my time. Good luck on the build.
Old Dec 18, 2016 | 06:54 AM
  #97
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
The turbo does seem like the more ambitious way to go. The V3 seams like the way to go especially when your good with 350-400 hp. I was wondering what happened to your car. One second it's getting a turbo, the next your brakes that are worth more than my daily driver are destroyed.
Old Dec 18, 2016 | 07:47 AM
  #98
terrasmak's Avatar
It hasn't been to the track since I had the hub come apart, it's actually only been driven a couple times since then. I got the new bearing, still need to press the studs, and install. Basically just been doing house work and riding my bicycle when I have time.
Old Dec 18, 2016 | 09:20 AM
  #99
03threefiftyz's Avatar
03threefiftyz
I actually am a bit surprised how much I like the V3 kit on track...drives like an NA car.
Old Dec 18, 2016 | 07:57 PM
  #100
dikspiel's Avatar
dikspiel
Chestons Toilet
dreamer build
