FI bug has bit, going Vortech
Old Dec 26, 2016 | 03:35 AM
  #121
Conway_160's Avatar
Conway_160
The Tim-Rod?
Yep
Old Dec 26, 2016 | 08:44 AM
  #122
terrasmak's Avatar
Originally Posted by Conway_160
Yep
I got that with the kit I bought
Old Dec 26, 2016 | 10:10 AM
  #123
BluestreamDE's Avatar
BluestreamDE
Originally Posted by OldManZ350
You will not fight any belt slip, if you just get a Radius Rod.
Is your Timrod sort of like an alternate brace to reduce or stop motor twist/torque when you don't have solid engine mounts? I actually have the Stillen Engine Damper and I experience no slip at all when I almost hit 14psi at redline. Does your Radius rod do something else specifically to the engine and supercharger mounting bracket? If so I'll buy one from you.
Old Dec 26, 2016 | 05:08 PM
  #124
OldManZ350's Avatar
OldManZ350
It is specifically designed for the VORTECH SC. Without the Radius Rod, the Vortech Bracket will flex under load, starting at about 10-12psi. When the Bracket flexes then the belt loosens and then slips. The Radius Rod stops that from happening. And it has held up to 28psi.
It does not affect the motor mounts.......
The Stillen Engine Damper CANNOT Help with Vortech Belt Slip.
Old Dec 27, 2016 | 09:40 AM
  #125
terrasmak's Avatar
First round of parts being ordered tomorrow. Couple parts to finish the fuel system and the 1 piece charge pipe.
Looking at the setup I bought, I may want to order a different intercooler. Drop from the treadstone 1045 to a TR8l to see if I can get the most air to my radiator.
Old Dec 27, 2016 | 11:00 AM
  #126
OldManZ350's Avatar
OldManZ350
I use a TreadStone TR 1245 and I have no problems with cooling and I'm using the stock radiator.
Old Dec 27, 2016 | 11:14 AM
  #127
BluestreamDE
Thanks for explaining the Timrod's purpose further for me, OldManZ350 I appreciate it.
Old Dec 27, 2016 | 01:14 PM
  #128
03threefiftyz's Avatar
03threefiftyz
Not in the same ballpark as Lens car in terms of cooling needs...
Len, I use the TR8. With stock radiator it overheats in 3-4 laps without ducting and 03 bumper. Ducting and a nismo bumper should keep it happy for a while in 80ish degree temps.
Old Dec 29, 2016 | 02:03 PM
  #129
vegasanthony's Avatar
vegasanthony
So you have a DE engine now... right Len?
Curious which belt routing diagram you plan to use
If you can post a pic that wiuld be great
Old Dec 29, 2016 | 09:55 PM
  #130
terrasmak's Avatar
That is a great question, it's probably going to be one based on not having a factory idles pulley.
Kit got here today, started going thru and inspecting everything. Need to get an order of parts started, then start hacking away on the install
Old Dec 30, 2016 | 06:12 PM
  #131
dikspiel's Avatar
dikspiel
Chestons Toilet
So proud of you
Old Dec 31, 2016 | 01:43 AM
  #132
OldManZ350's Avatar
OldManZ350
Interested to see how you set-up the Blower Drive.......
Old Dec 31, 2016 | 04:42 PM
  #133
terrasmak's Avatar
Put my TR1045 up for sale , time to measure and figure out if I'll get a TR8 or TR8L
Old Jan 3, 2017 | 07:29 PM
  #134
terrasmak's Avatar
Got a stock vortech intercooler on the way.
Old Jan 3, 2017 | 07:32 PM
  #135
OldManZ350's Avatar
OldManZ350
Do know how much boost you are going to make, but the stock vortech IC is only goos to about 7-8psi.
Old Jan 3, 2017 | 08:01 PM
  #136
terrasmak's Avatar
No idea , probably the 3.13 with fluiddamper spun to 7500 on the built motor. Just the 3.3 pulley and maybe the fluiddamper on the current motor for now.
Old Jan 20, 2017 | 09:22 PM
  #137
terrasmak's Avatar
Parts are all ordered , should only need a few fittings and the return hose. Need to figure out what -6 hose to use ( so many types available ) and of course the tricky part of of how to plumb everything by the tank. Need to come up with a hose routing solution for the surge tank. Figure I'll run the car NA for a few days once I get the fuel system done, just for testing.
Old Jan 24, 2017 | 09:53 AM
  #138
dikspiel's Avatar
dikspiel
Chestons Toilet
Pics or I will drive over
Old Jan 24, 2017 | 09:10 PM
  #139
terrasmak's Avatar
Need the address?
Someone learn me some info on fuel line. Obviously -6 from the fuel rail to the regulator mounted on the firewall, then -6 back to my surge tank near the fuel pickup area. Steel braided , nylon braided , smooth covering , what version of -6 fuel line is the right one to run.
Old Jan 25, 2017 | 03:21 AM
  #140
2bad240's Avatar
2bad240
Need the address?
i have used steel braided. Nylon braided. Gates Barricade rubber fuel hose. Vibrant rubber fuel hose. All depends on what you want to spend I guess. I have SS feed and rubber return on my car. When looking for the right hose look for rated psi and what chemicals it's made for
