Twin scroll or bi-turbo?
Old Apr 25, 2016 | 01:05 AM
tcode's Avatar
tcode
Default Twin scroll or bi-turbo?
Twin scroll any day!!
This is a comparison between friends 350z with built motor and Greddy 18g bi-turbo kit (red curve) and mine, big single twin scroll turbo (blue curve). Very little difference in low rpm area.
Both motors having 8.8:1 CR, a friends bi-turbo have stock cams, while mine having JW C8 cams, which are quite aggressive. I can bet, with stock cams my motor would outperform bi-turbo in lower rpm's too. And the turbo I'm using is a Precision 6766 with billet upgrade compressor wheel, exhaust housing A/R 1.32.
Old Apr 25, 2016 | 04:10 AM
wisniaPl's Avatar
wisniaPl
Nice numbers looks like a beast especially up there where greddy stops making power
Is that boosted performance mid mount kit?
Old Apr 25, 2016 | 05:00 AM
tcode's Avatar
tcode
Yes and no. Originally it was single scroll Boosted Performance kit which I bought 2nd hand here on boards and convert it to a twin scroll.
This power is made with "low boost", 1.2 Bar or 17-18 PSI, couldn't crank it more because wastegate springs were too soft. Retune will be soon, expecting to make more power and peak boost at 1.5 Bar.
Here's a difference between standard PT 6766 (left on the pic) and upgrade billet compressor wheel (right)
Thanks man!
Old Apr 25, 2016 | 09:36 AM
rcdash's Avatar
rcdash
Congrats on the power but there are too many variables to make this a valid comparison. That said, if I was doing it all again, it would be a single twin scroll. Mostly because of cost, simplicity, availability, and accessibility. Not for power (you can compare our power curves and two small twins is hard to beat - 500 whp at 4k rpms)... We are lucky to have BP developing high quality and affordable twinscroll kits for our platform!
Old Apr 25, 2016 | 06:30 PM
Resmarted's Avatar
Resmarted
Yeah like RC said, the differences between the greddy tt kit and a new billet cea wheel are huge. Twin scroll helps, but billet wheel probably did just as much if not more. It gives the vanes more aggressive angles, so it flows better.
Nice curve though, sure it's a great car to drive!
Old Apr 25, 2016 | 08:25 PM
bealljk's Avatar
bealljk
subscribed - nice work T!
Old Apr 25, 2016 | 11:34 PM
tcode's Avatar
tcode
An upgrade billet compressor wheel is heavier (not much but is) and while it flows more indeed, it negatively effects on the spool.
We will probably upgrade friends 18g twins later this year, I'll post results here.
Also, I'm not using Precision exhaust housing. Instead, went with Mamba P-trim housing which needed some machining to fit PT turbine shaft. And that might have much bigger impact on spool.
Anyway, true, the car drives like a champ .
Thanks!
Old Apr 25, 2016 | 11:40 PM
tcode's Avatar
tcode
James, without you I couldn't get so far or at least not that quickly! Thank you for your patience with me and my countless requests for reshipping stuff overseas.
You were always be so kind, hopefully we will met some day and drink a couple of beers .
P.S.
Finally started dressing engine bay, not done much so far but hey, it's a progress
Old Apr 26, 2016 | 07:38 PM
Resmarted's Avatar
Resmarted
Thanks!
The reason cea's keep flowing at such high psi is because they're more efficient per revolution. I wasn't talking about impeller speed but, flow. If you have a turbo that flows more at lower turbine speed, you have one that should be more efficient at high turbine speed. Something we know is true for precisions.
Again the comparison between a billet single and old school mitsu twins is really hard to make, because they are inherently different.
Old Apr 26, 2016 | 08:31 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Congrats...those are some solid numbers.
That turbine is available in 1.52 a/r as well.
Old Apr 26, 2016 | 11:02 PM
tcode's Avatar
tcode
Understandable, but still, we are here talking about almost double power capable turbo system (PT6766 is 930HP rated, and with this billet compressor probably over 1000) with almost same efficiency at low rpm as smaller turbo's system.
Sacha, thanks! Yes, I knew about 1.52 before purchasing A/R 1.32 exhaust housing but my biggest concern was will it fit without compromising turbo height position. I'm very happy how it performs and can't stop thinking why I didn't do it much sooner. This twin scroll design is much much efficient than your first, single scroll design. Difference is night and day!
Old Apr 27, 2016 | 09:56 AM
Resmarted's Avatar
Resmarted
Single is absolutely the better choice. But we are comparing mitsu jb turbos on log manifolds, parts of a kit that is over 12 years old, to the latest billet single kit. And I think that's the crux of the comparison. It doesn't mean your kit is not great, because it's pretty much the best street single setup you can run give or take specific turbo specs.
Old Apr 27, 2016 | 04:45 PM
jerryd87's Avatar
jerryd87
think you have some things mixed up dude
1)the billet cea 6766 is rated at 935, the OLD cast 67's where like a 700 hp turbo, the billet 6765 was a huge jump and then when they went to the 66mm cea exhaust wheel it made another jump in power.
2) cast vs billet wheel the billet will always be lighter for the same size, billet is stronger allowing thinner everything, if a billet wheel is heavier its because its running a wheel with longer fins or more and even then its doubtful to be heavier at best match the weight. This is a big reason the billet turbos spool faster. In fact i know of a billet 76 that will spool about on par with the 6766 cea and make 1400 hp each...... however with the options to do it the turbo is about $5500....... i know as im going to be running two of them
3)as they said the twins use old school turbos, they are using cast everything and compressor and impeller designs that are ancient. the design of the wheels alone play a huge part. those turbos are 50mm and realistically the most your going to put out is about 400 per turbo, the closest you will look at comparatively in new design would be a precision 55, which is 500 hp for the MFS and 590 for the billet CEA turbos both of those turbos will outspool the 18g's from being both lighter in rotating assembly and more efficient designs. all things equal twins will outspool a single, a single is usually easier to package for a given power without moving twins to some location that kills the advantage of their spool being closer to the exhaust ports.
Old Apr 29, 2016 | 02:32 AM
tcode's Avatar
tcode
I was comparing weight of 6766 CEA billet and UPGRADE billet compressor. 111 vs 120 grams.
Personally, never seen 18g twins making 800 HP. Did you?
Old Apr 29, 2016 | 10:58 AM
jerryd87's Avatar
jerryd87
This engine? No other smaller engines yes could swore I saw some reference to them being 500 whp turbos that's what I was referencing.
Upgraded billet wheel? From where? Last I knew precision never released a gen 2 6766
Old May 1, 2016 | 07:36 PM
kilogram's Avatar
kilogram
Cool. Now throw a pair of 14 blade ET billet KTS wheels and 9 blade 05h turbines into the MHI turbos, run the same boost and do the comparison. I can't believe no one ever upgrades the Greddy/MHI turbos to all the new aero that's available.
Old May 19, 2016 | 03:58 AM
tcode's Avatar
tcode
It's a custom made upgrade compressor wheel, not from Precision.
Anyway, final numbers at 1.5 bar (22 PSI)
Pump gas, stock heads except cams.
Old May 19, 2016 | 11:53 AM
Highway Riding's Avatar
Highway Riding
Bravo on making that much on pump gas!
Old May 23, 2016 | 05:32 PM
Escobar's Avatar
Escobar
Nice numbers, 800 is rowdy!
Old May 23, 2016 | 05:48 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
compare to my greddy TT setup, 18psi
3000 140
3500 250
4000 370
4500 480
5000 550
5500 610
6000 640
6500 630
Will show that the TT provides a fatter midrange while giving up at the top.
Was your buddy on wastegates only or any kind of boost controller?
But yeah.twin scroll is the way to go now.
