Koyo 53mm radiator on Greddy TT engine
Old Jan 13, 2017 | 07:52 AM
eZg's Avatar
eZg
that was one hell of a post aarrgghh......thanks for sharing
Old Jan 13, 2017 | 11:26 AM
aarrgghh's Avatar
aarrgghh
Originally Posted by rcdash
aarrgghh, nicely done. I've not seen anyone use a solid state relay and the Haltech before this on our platform. The only recommendation I would make to your set up is to make the fans easily removable without having to remove the shroud because the fans will fail and it's messy to remove the coolant tubing to get the shroud off just to get a failed fan off. After I had to do it the first time, I used rivet nuts so next time around will be easier. My first set of 14" SPALs lasted about 4 years (both failed about 1 yr apart). Now on 2nd set. They move a lot of air.
EDIT: The crydom SSR is pricey - and I see you put a heat sink on it. job done right!
My trick for this is to cut the bottom off an old washer fluid bottle from the gas station, place a bunch of shop towels then this under the passenger side return hose. Then you can pull the hose and cable tie it up to itself or the strut bar so it doesn't drain. A little bit of coolant from the rad side goes into the container. Pull the container and the shroud pops right out. But I'll have a look at your solution when I reassemble the car next.
I'm surprised using an SSR isn't too common. That way the fans aren't screaming like the bat mobile if they don't need too.
To get the current rating with reasonable temperature derating needed both the 100amp and heat sink. As the fans keep my investment in the engine cool, it's worth it.
Old Jan 17, 2017 | 09:00 AM
rcdash's Avatar
rcdash
The alternative is a PWM fan controller (manufactured by DIF, Delta) but getting a quality unit is a little hit or miss (my first DIF controller died in a year; had to move it to someplace that got more airflow). If/when my controller dies, I will use an SSR.
Old Feb 8, 2017 | 01:35 PM
R6n350GT's Avatar
R6n350GT
how does the stock fan shroud compare with the aftermarket shroud and SPAL fans? i have 12" Spal (not sure which type) and wondering if i should try and go back to stock fans...
Old Feb 9, 2017 | 02:21 PM
aarrgghh's Avatar
aarrgghh
Unless you have the deep high output spal 12's, you're probably not pulling more air than the stock setup.
I never could find good cfm data for the stock setup.
Old Feb 10, 2017 | 05:27 AM
Conway_160's Avatar
Conway_160
Is there a way to test the cfm's of a stock fan?
Old Feb 10, 2017 | 11:39 AM
aarrgghh's Avatar
aarrgghh
The CFM will vary with the pressure drop across the rad, etc.
The Spal fans have a chart for this. I graphed several while making a call on which to use:
The blue line is the 14" fan I bought, the green is a 12" high output. At the pressure drop I measured (5.5 mmH20) the 14" pulls more.
Anyway, you'd have to find a way to measure the amount of air moved, but without changing the pressure behind the fans as that will affect the measurement. I've seen something similar done with building vents, and they use a calibrated box that pipes down to a 12" ish size tube that they have a MAF in. You'd have to pull an engine out to get enough space for the measurement rig.
Old Feb 10, 2017 | 12:24 PM
R6n350GT's Avatar
R6n350GT
Ill try and get a piv of what they are. But would that be a cause of overheating ?
Either that or swirl pot cauing issues, koyo 53mm rad blocked, thermostat and water pump are new...
Or front bar is to restricted..
