Turbine A/R
Old Aug 23, 2017 | 03:09 PM
superpreditor's Avatar
superpreditor
Default Turbine A/R
Good evening.
In the middle of a custom turbo kit with 5757 turbos .48a/r and wanted to get opinions on whether or not theyll be restrictive in the upper RPMs.
I've Kelford 272 camshafts and valve train.....looking to make 500whp pump revving to 7500rpm.
Old Aug 25, 2017 | 10:10 PM
bealljk's Avatar
bealljk
why custom build?
Explain your setup a little bit?
Old Aug 26, 2017 | 11:40 AM
superpreditor
5757 attached to aftermarket header with tial 38mm on turbine housing.
8.5 compression motor.
Old Aug 28, 2017 | 01:28 PM
rcdash's Avatar
rcdash
A single 5757 with that small A/R I don't think will make 500 to the wheels. Lots of variables of course. I think you might hit 500 at the crank, maybe 450 wheel?
Old Aug 28, 2017 | 07:05 PM
CK_32's Avatar
CK_32
What I was taught (for the most part) was in most applications of max power, bigger a/r is almost always better.
Of course some set ups are different but a bigger a/r will probably be better.
With my 6266 scroll kit I opted For one of the biggest a/r's avalible by recommendation of the builder of the kit. So far I'm not disappointed with my base line tune.
My second touch up appointment is this Saturday.
Old Aug 28, 2017 | 07:33 PM
BoostedProbe's Avatar
BoostedProbe
He is talking twin 5757's with T3 .48 A/R turbines. That combo should get you 650whp on pump gas all day long.
Old Aug 31, 2017 | 11:14 AM
rcdash's Avatar
rcdash
lol, well single vs twins is definitely different. When he said aftermarket header, I figured it was a single.
Old Sep 1, 2017 | 09:15 AM
CK_32's Avatar
CK_32
Yea not ganna lie I thought we were talking about a single this whole time lol
Old Sep 1, 2017 | 10:49 AM
iideadeyeii's Avatar
iideadeyeii
Originally Posted by superpreditor
Good evening.
5757 turbos
turbos
bos
os
s
A single 5757
Old Sep 2, 2017 | 07:26 AM
rcdash's Avatar
rcdash
Hey at least I clearly stated "single"; and why would anyone be wondering about twins turbos with 75mm compressor wheels making 500 whp??? Those turbos are rated like 550 hp (each!).
Old Sep 4, 2017 | 06:44 PM
superpreditor
The concern wasn't whether it'll make the power, it's whether or not the power band will continue to 7500 rpm with .48ar
