Where does everyone have their line tapped for boost gauge?
Old Aug 25, 2017 | 08:47 AM
crd00's Avatar
crd00
Default Where does everyone have their line tapped for boost gauge?
Where does everyone have their line tapped for the boost gauge? I followed the only writeup I could find online and ran a line to the nipple on the front of the plenum but the boost readings arent consistent. Im assuming its the wrong location.
Ive read of a few spots to T into but cant see any clarification on it. Pictures would also help! Thanks!
Old Aug 25, 2017 | 10:30 AM
iideadeyeii's Avatar
iideadeyeii
There's a line off the rear of the plenum that I put a T-fitting on and I get mine from there.(pretty sure I had to reduce the size)
Old Aug 25, 2017 | 11:50 AM
bealljk's Avatar
bealljk
for a boost gauge off the plenum. I'd look into a vac block.
@ii, are you plumbing your side-port waste gate from the plenum? (hard to tell from the picture)
Old Aug 25, 2017 | 12:20 PM
crd00's Avatar
crd00
Thanks for the replies guys, currently I have my a/f ratio gauge from the hose you are specifying dead eye, so I can tap into it again for the boost gauge?
Like I said, I currently have it from the nipple on the front passenger side of the plenum, but every time I start the car the boost gauge needle is at a different number, its not consistent. Its not reading negative pressure so this nipple area must be no good Im assuming.
If it helps, I'm running a voretch v3 supercharger
Old Aug 25, 2017 | 12:59 PM
iideadeyeii
That's not my picture. I just grabbed it off google to show which place i was talking about that I tapped into.
Old Aug 25, 2017 | 01:00 PM
iideadeyeii
a/f comes from exhaust
Old Aug 25, 2017 | 02:24 PM
crd00's Avatar
crd00
Sorry, didnt mean a/f ratio, i meant my bypass valve
Old Aug 25, 2017 | 03:22 PM
Nic Boitnott's Avatar
Nic Boitnott
I have my blow off and boost gauge from that line deadeye mentioned, with consistent readings.
Old Aug 25, 2017 | 05:42 PM
bealljk's Avatar
bealljk
Thank god!!
Old Aug 25, 2017 | 07:29 PM
crd00's Avatar
crd00
Anyone else have a boost gauge installed in their 350?
Old Aug 25, 2017 | 09:51 PM
bealljk's Avatar
bealljk
Everyone has a boost gauge installed on their 350z...
what's your concern? why are you worried? what are the inconsistencies? it's a stupid gauge doesnt mean much...just tap it off the plenum and be done...
Old Aug 25, 2017 | 10:30 PM
Nic Boitnott
Old Aug 28, 2017 | 08:28 AM
crd00's Avatar
crd00
LOL relax there bud, no worries on this end. I paid x amount for this gauge and its not working correctly where I have it "tapped off the plenum" where you suggest.
Ill throw in a nipple where my blow off valve is and see what happens. Thanks for the replies deadeye and nic
