VQ37 Engine Dimensions
Old Sep 5, 2017 | 04:26 PM
yzaffa1's Avatar
yzaffa1
Default VQ37 Engine Dimensions
I am trying to find the dimensions length, width, height on the VQ37 motor to see how it will fit in a Datsun 521. It appears that I have height and width of the motor at the top, for a VQ35, but I am trying to find the length and the width at the base. Could someone please point me in the right direction as I have been trying to google the information for a bit. Also the distance and height of the location where the motor mounts would bolt up. I figure carving some card board up would be better then just purchasing the motor out right without knowing if I can fit it.
Old Sep 7, 2017 | 02:41 PM
Conway_160's Avatar
Conway_160
If im not mistaken the dimensions of the block its self is exactly the same, all the changes were internal to the block. The only difference would be the intake setup.
Old Sep 7, 2017 | 08:24 PM
yzaffa1's Avatar
yzaffa1
Yes I assume that, however I do not have the full dimensions for a VQ35 either.
Old Sep 8, 2017 | 02:27 AM
Conway_160's Avatar
Conway_160
What dimensions do you need?
Old Sep 8, 2017 | 06:16 AM
yzaffa1's Avatar
yzaffa1
Length and width of the block
Old Sep 8, 2017 | 07:35 AM
rancor's Avatar
rancor
We are talking VQ35HR vs VQ37VHR correct? I don't have any dimensions but the VQ37VHR does have the cam actuators on the head that I think sit on the rear of the motor.
Old Sep 8, 2017 | 10:47 AM
yzaffa1's Avatar
yzaffa1
I was mainly looking for the VQ37, I am looking to see if I can fit it in a Datsun 521 without having to do too much work. I also have access to one for $400. But since they are similar the VQ35 length and width should be roughly close.
Old Sep 9, 2017 | 04:55 AM
Conway_160's Avatar
Conway_160
Here is all the dimensions from a DE, the are all rounded slightly so to be on safe. The HR may be a little bigger do to the front cam cover having two VVT on each bank.
Old Sep 9, 2017 | 07:25 AM
yzaffa1's Avatar
yzaffa1
Greatly appreciated! Think this actually gives me a bit more info that I may be able to squeeze it in there.
Old Sep 9, 2017 | 09:05 AM
Conway_160's Avatar
Conway_160
No Problem, LMK if you need any other dimensions.
Extreme Dimensions
Body Exterior
23
Jan 4, 2017 09:00 AM
Swaglife81
Oct 31, 2016 04:25 PM
FairZWell
Oct 20, 2016 08:30 PM
Extreme Dimensions
Body Exterior
Oct 13, 2016 02:20 PM
Extreme Dimensions
Southern California
Oct 3, 2016 09:28 AM
