Best compression for Vortech v3 build w/ 91 octane?
Old May 21, 2018 | 10:34 AM
BluestreamDE's Avatar
BluestreamDE
Originally Posted by Michael Zosa
If the maximum I'll aim for is 500whp, do you recommend I get the L19 Studs over the regular ARP?
I am sure you will be fine with regular ARP Studs for just 500whp, however I suggest on buying it just for the added insurance that the L19 studs will offer more reliability and durability keeping the heads all holding together to the block.
Old May 21, 2018 | 10:36 AM
0taku's Avatar
0taku
I was on normal ARP head studs at 494whp with no head lift on the dyno.
Although, regardless you should go L19's either way and not skip out on that. Also, on 91, I'd recommend 10:1 or lower compression solely for longevity concerns and the added comfort of less tuner error.
Old May 21, 2018 | 10:52 AM
bealljk's Avatar
bealljk
Originally Posted by bealljk
If you had it all over again - what, if anything, would you do different?
No point in living in the rear-view, but if I did it all over, I'd have gone single turbo from the start. I had ATIs procharger and nothing but good things to say about my setup ... but it was wasted time & money ...
Originally Posted by vegasanthony
maybe I should have gone E85 from the get-go but the E85 station is definitely not around the corner from me add to the fact with the guy with the Evo down the street test his E85 from there and it's always different.
No e85 for this kid ... too many things to change on my already complicated setup. I'll stick with 91oct & water meth...something that rarely comes up and I didn't know is that your oil change interval drops to ~1000miles between oil changes with E85.
If it was me, I'd go with the L19.
If youre gonna do the build the L19 is a solid way to ensure you're head stays put and they are re-useable if you have to take the heads off in the future. It'll add $250 to your build but it's worth it.
With that being said - no headstud will save your engine from a bad tune / detonation.
Old May 28, 2018 | 11:50 AM
wizard's Avatar
wizard
Sorry I just caught up with this post.
If your target is up to 450bhp you should just cap the torque below 370 lb/ft and your stock block will be fine.
I've had this kind of setup longer then most folk, but I'm forged now and going above 500. It's a lot of money for an extra 50bhp+.
Old May 28, 2018 | 12:47 PM
vegasanthony's Avatar
vegasanthony
L19. Without a doubt..and
uprev oil pump
the money spent is negligible when you calculate the money spent on engine build
P&K350Z
Mar 28, 2015 09:42 AM
nismo240r
Jul 9, 2008 03:26 PM
STL_Z_Seller
Aug 31, 2005 08:47 AM
Z BOY
May 17, 2005 06:42 PM
sentry65
Mar 3, 2005 05:49 AM
