Vortech: Intermittent lean fuel pressure problem!
Old Aug 3, 2018 | 07:07 PM
BigBlue's Avatar
BigBlue
Originally Posted by wizard
do you have a pic of how you did it? I’m quite surprised- do you have a fuel return system?
sorry I don't have a pic of the install; was done at a shop where they did the whole return fuel kit. Here is a link of the pump that is now in the car: https://www.z1motorsports.com/fuel-s...et-p-5287.html
Old Aug 6, 2018 | 12:47 AM
wizard's Avatar
wizard
I just realised that I was running the 11542 and not the 11140 like yourself. Do you know what filter sock the shop used, was it OEM or the one which comes with the kit?
Old Aug 7, 2018 | 07:42 AM
OldManZ350's Avatar
OldManZ350
The Stock Fuel FEED Line is very Tiny less than 1/4" inside diameter.
You just CAN"T Pump your Fuel Requirements through that TINY STOCK Feed Line.
Install a CJ Motorsports Stage 2 Fuel System. It works great. Fuel Problems will go away, and will get rid off a ton of crazy tunig issues.
https://cj-motorsports.com/products/...-system-vq35de
Get it with the Aeromotive Fuel Regulator and the Mini Pressure Gauge
Make sure you fuel Pump is installed correct.
Old Aug 10, 2018 | 02:58 PM
BluestreamDE's Avatar
BluestreamDE
Ever find out what the problem was, Wizard?
Old Nov 19, 2018 | 05:05 AM
wizard's Avatar
wizard
Update:
Yes found the issue. It was a failing fuel pump - it actually seized up completely a week later.
I feel it could have been caused due to the restrictive fuel sock / improper installation.
I have installed the DW300 now and the car.
Old Nov 19, 2018 | 02:21 PM
BluestreamDE
Good stuff! Glad it worked out!
Juztin
Mar 28, 2021 10:21 AM
wizard
Jul 31, 2018 01:44 AM
Tintspectrum
Apr 25, 2016 04:24 PM
dirtroad
Mar 15, 2006 05:33 PM
petert69
Jul 1, 2003 09:04 PM
