F.I. and High Altitude Question
Old Feb 22, 2004 | 05:51 PM
Bottom's Avatar
Bottom
Question F.I. and High Altitude Question
I was wondering if anyone had any knowledge or experience with a forced induction system and high altitude. I'm in Colorado and I know that I won't be able to compress as much air as sea level. I know a little about superchargers versus turbos, but not with thin air.
One question I had was if there is a major advantage with turbo or superchargers at this atmospheric pressure.
Thanks,
DK
Old Feb 22, 2004 | 08:20 PM
Juztin's Avatar
Juztin
Yeah, without FI @ altitude, the car simply sucks...
Old Feb 23, 2004 | 04:50 AM
jesseenglish's Avatar
jesseenglish
Superchargers you will not make as much power unless you swap to a higher boost pulley, a proper turbo setup with a MAP sensor, you will make equal power to someone at sea level.
You lose a little more than 2 PSI at your elevation.
Old Feb 23, 2004 | 10:44 AM
newmexicoZ33's Avatar
newmexicoZ33
Bottom,
to give you an idea of the difference FI makes at high altitudes, here is a quote from the NHRA altitude correction factors page,
NOTE: Supercharged and/or turbocharged cars (i.e.: AA/A, AA/AT, BB/A, BB/AT, A/PM and AA/PM) use half factor
...meaning generally the loss is half the time. I am at over 5000ft, I see the difference between boosted and N/A cars all the time. Like someone already said, without FI it sucks.
Old Feb 23, 2004 | 12:14 PM
etx's Avatar
etx
Here I get about 105 kpa, at higher levels you may see only 90 kpa! Thats ~12% less air. Less air = less petrol == less power.
Alexreyes
Sep 30, 2015 11:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
