Question about boost controllers and external wastegates
Old Aug 23, 2022 | 09:08 PM
_sleeperzzz's Avatar
_sleeperzzz
Default Question about boost controllers and external wastegates
Hi, this is my first post here.
I am running a Greddy Twin turbo kit on my DE motor, and it's currently pushing around 5 psi of boost. I don't have a boost controller on the car but I am thinking of getting one (AEM truboost) and buying the other springs for the wastegates (TIAL/Greddy).
Would this work? I want to be able to push 20 psi of boost when I want to (My current build is more than capable) but obviously not all the time and I want to be able to turn it back down to around 5 psi after. Can someone let me know if this would work if they have already done it? Thanks!
Old Aug 24, 2022 | 05:32 AM
GreyZ's Avatar
GreyZ
That is exactly how boost controllers work, but it is not recommended to go over double spring pressure. If you want a max of 20, you need to run a 10 lb spring.
20psi is quite a bit of boost in these motors. That would likely put you deep in the 600s. I also don't recall that the greddy twin kits are efficient at all at those pressures and you will likely run into other issues.
jtgli
Jul 2, 2008 05:59 AM
III
Apr 9, 2008 01:33 PM
clemlover15
Oct 4, 2006 02:34 PM
Fairlady_z33
Nov 15, 2005 05:48 AM
