Interesting Oil Temp readings....
Old Mar 4, 2004 | 08:15 AM
Chebosto's Avatar
Chebosto
Default Interesting Oil Temp readings....
well, in continuation of oil temp readings. i did some more data logging.
The oil temp on my turbo setup, @ 8.5psi, was AMAZINGLY lower than what was previously recorded.
the PE turbo setup adds a 40 row- cooling fin oil pan, that holds 1 more quart than stock.
for example of how drastic of a change oil temp was during open-road field testing of the TT during development, we had a peak operating oil temperature of 115*C with the stock oil pan.
with the setup now, the peak operating oil temperature i've seen is 95*C
During normal cruise w/o boost before the new pan @ 3k RPM, 80mph, in 6th gear, was 90*C
Now normal cruise w/ boost is 65*C!!!
i had purchased an permacool oil cooler to help in cooling the oil down, but this new oil pan is bad azz.
just wanted you guys to know--
Cheston
Old Mar 4, 2004 | 08:18 AM
Chebosto's Avatar
Chebosto
Old Mar 4, 2004 | 08:24 AM
toykilla's Avatar
toykilla
nice! how much is that oil pan by itself ?
Old Mar 4, 2004 | 09:20 AM
Chebosto's Avatar
Chebosto
56000 yen
Old Mar 4, 2004 | 12:12 PM
g356gear's Avatar
g356gear
Originally posted by Chebosto
56000 yen
$500 US $675 CDN
Old Mar 7, 2004 | 06:03 PM
daking350's Avatar
daking350
How much of a P.I.T.A. is it to install??
Old Mar 7, 2004 | 06:09 PM
jesseenglish's Avatar
jesseenglish
$500 for a friggen oil pan!!!! Holy crap. OK, time for an inventor here to reduce the costs. If it does help that much, I'd pay $200, but no way, I'd pay $500.
Old Mar 7, 2004 | 06:17 PM
daking350's Avatar
daking350
How about a generic B&M import oil cooler??
Old Mar 7, 2004 | 07:03 PM
islandsnow's Avatar
islandsnow
i'd rather install this than an oil cooler, less than the nismo oil cooler kit too. Cheston, is there any clearance problems or does it hang any lower than the stock one?
Old Mar 7, 2004 | 07:10 PM
jesseenglish
I don't think clearance would be a problem because there is plenty of room below the engine. I do have a question regarding the extra capacity though. I think the cooling effect has more to do with the extra capacity than the fins. Mainly because there's not a whole lot of air getting through there anyways.
Big question though, did it come with an extended oil pick-up tube?
Old Mar 7, 2004 | 07:42 PM
jesseenglish
I'd like to get something like this.
Basically, a stock oil pan with baffles added for high speed cornering. The T baffles would also add extra capacity. All to be had for cheaper than the PE one. Anyone got an extra oil pan they can send off to this company so they can develop one for the 350Z??
http://www.cantonracingproducts.com/...ce/import.html
Old Mar 7, 2004 | 09:08 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Yeah, I tend to agree here. When you increase the oil volume circulating by 20%, you'll likely get a 20% drop in oil temp. It would be great if someone could just make a standard type oil pan, but with a 6qt capacity.
Old Mar 8, 2004 | 05:06 AM
ravaz's Avatar
ravaz
I do.
Old Mar 8, 2004 | 05:14 AM
jesseenglish
I'll call them up today and see what they can do with it.
What kind of material is the oil pan made of? Aluminum? Steel? Is it cast or stamped??
Old Mar 8, 2004 | 05:17 AM
ravaz's Avatar
ravaz
Yeah tell them they can use mine for development or whatever, I'll ship it out whenever, just let me know. I don't remember what it's made out of, I think it's Aluminum, I'll have to check.
Old Mar 8, 2004 | 05:23 AM
jesseenglish
I'd need to know. If it's cast aluminum, it's probably gonna be more expensive because it's harder to weld on. Might not be worth it depending on the cost.
Old Mar 8, 2004 | 06:58 AM
Bini2's Avatar
Bini2
I am definitely interested in purchasing a larger oil pan, gl jess. Let me know if I can help in any way.
Old Mar 8, 2004 | 07:46 AM
etx's Avatar
etx
That PE oil pan is very very nice. I may pick one up. How is ground clearance with it on? Does the stock cover fit under the engine bay with it installed?
Old Mar 8, 2004 | 02:11 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I don't think that $500-$700 is too bad for a cast aluminum piece like the PE or ARC ones are honestly. You ahve to remember that in manufacturing, volume dictates price. There is, without a doubt, a much higher demand for a Honda/Acura pan than there is for a 350Z one....
Old Mar 11, 2004 | 02:42 PM
jesseenglish
OK, finally got a response back from Canton Racing Products. Apparently they also need a stock pickup. Anyone got one.
Ravaz, did you find out if it's cast aluminum or steel yet?
DEAR JESSE,
TO HELP YOU OUT WITH FABBING YOU A PAN WE WILL NEED THE FOLLOWING,
A STOCK PAN
A PICKUP
A DESCRIPTION OF THE OIL PUMP LAYOUT (CRANK DRIVEN ?)
DETAILED PICTURES OF THE UNDER CAR
STARTER LOCATION
AND DISTANCE OF ANYTHING NEAR THE PAN IE ( STARTER, STEERING, EXHAUST)
Thank you,
