Greddy TT + e-01 people, Can you read the greddy map from the emanage?
Old Mar 19, 2004 | 07:04 AM
etx's Avatar
etx
Default Greddy TT + e-01 people, Can you read the greddy map from the emanage?
I can. Mabye Greddy forgot to lock my emanage. I am not sure...
On the e-01 can you import the data from the emanage and review the add injector map? I would try to post the info, I saved it to the memory card on the e-01. But I do not have a reader to read the card on my PC. I am not sure that the card is even i a PC readable format. Has anyone tried this?
Old Mar 19, 2004 | 10:16 AM
03_ppw350z's Avatar
03_ppw350z
i am going to try this but when i import it will i have to export it back to the emange to have the program still
Old Mar 19, 2004 | 10:18 AM
etx's Avatar
etx
Nope, nothing will be over written if you do not export. Just import it into the e-01 from the emanage, the data will still stay on the emanage unless you edit it and then export it back to the emanage unit.
Old Mar 19, 2004 | 12:05 PM
03_ppw350z's Avatar
03_ppw350z
ok thanks bud can i ask you what do you have oyour gain and start boost set too?
Old Mar 20, 2004 | 07:58 AM
etx's Avatar
etx
Gain is at 10, start boost is at 4 psi
Old Mar 21, 2004 | 11:09 AM
03_ppw350z's Avatar
03_ppw350z
i thnk greddy didnt lock your emange becuase i cant get it to import it jus says somthing about the password.
Old Mar 21, 2004 | 12:44 PM
etx's Avatar
etx
Hah! Sweet. I can load it into the e-01 no problem. Anyone want the greddy map?
Old Mar 21, 2004 | 08:41 PM
swinke's Avatar
swinke
Yes please! I would like to know how much timing they are pulling for the boost. Or is the ignition harness even in the kit?
Old Mar 21, 2004 | 10:06 PM
03_ppw350z's Avatar
03_ppw350z
the ignition harness is not included they say they went 4 months with the ignition harness then they blew a coil pack but they were not sure the harness was the cuase. etx i would like the greddy map also if your willing to share it
Old Mar 22, 2004 | 07:57 AM
etx's Avatar
etx
Yeah it does not use the ignition harness. I think they just tuned it very rich to protect against any predetonation. After pulling the stock cats to install the test pipes after only 30 miles on the kit and only boosting a couple times the downpipes had a lot of carbon buildup. This map is very very rich. I'll post it when I get home tonight.
sales@czp
Sep 23, 2019 03:30 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
