Tires for turbo?
Old Apr 3, 2004 | 02:53 PM
DLin05's Avatar
DLin05
Question Tires for turbo?
all you guys with forced induction or plans for fi, what do you do about tires? would you just get better gripping tires or go wider? how would the stockers do with over 350whp?
Old Apr 3, 2004 | 10:26 PM
slay2k's Avatar
slay2k
I'd be interested in this discussion myself... how many people with 400whp drive stock tires ?
Old Apr 4, 2004 | 07:21 AM
fluidz's Avatar
fluidz
Hoosier's and Proxie's..............
Old Apr 4, 2004 | 07:47 AM
jesseenglish's Avatar
jesseenglish
Nitto 555's here. Couldn't imagine running stock tires, my 275's in the back slip enough as it is.
Old Apr 4, 2004 | 12:05 PM
PoWeRtRiP's Avatar
PoWeRtRiP
for 400 whp youll need something like 295's or larger in the rear. id recommend something real sticky like 555's, gforce, or equivalent. though if you drive it on the street a lot you may want an EBC with a low boost setting around 4-5 psi for civility.
Old Apr 4, 2004 | 12:38 PM
pinoy4065's Avatar
pinoy4065
yeah dont imagine 350+rwhp with stock tires i'll tell you cuz i'm doing it worse right now. I'm on stock tires that are bald and damn i cant even boost really unless i am on the freeway(and damn over here it has been dizziling a lot so even worse), so good discussion i have been looking for some tires right now, but i have a question what do u think is the widest tire i cant fit on the track rims?
Old Apr 4, 2004 | 12:44 PM
spazpilot's Avatar
spazpilot
Toyo TS-1 275X35X19 rear on 19X11. You need wider and sticky
Old Apr 4, 2004 | 01:25 PM
pinoy4065's Avatar
pinoy4065
wow u can fit a lot wider tire on that rim can't you! only 275??????
Old Apr 4, 2004 | 02:59 PM
mr2fasterthanyo's Avatar
mr2fasterthanyo
it depends on your uses for the car
i have run BF Goodrich Comp TA Drag radials (dont last very long though)
also have run Dunlop Sport W-10's and they gripped well
and ran Yokohoma AVS- sport (about $200 a tire)
that worked well.
widest i ran was 235 on the mr2's (dyno'd at 387 RWHP and 335ft/lbs) and while i could light them up, they weren't too bad, i also had the advantage of the weight of the engine on the back wheels.
what are you planning on using the car for? are these tires to be daily driven, raced, drag? that would help us
toyo's are very good tires as well
Old Apr 4, 2004 | 03:15 PM
zimbo's Avatar
zimbo
Search doesn't seem to work these days so I'll ask in this thread... Anyone use the BF Goodrich G-Force T/A drag radials as their regular tire? Yeah, seems pretty expensive as a daily driver tire but I'm just wondering if it would be feasible.
If not as a street use tire then how about on the track?
--Steve
Old Apr 4, 2004 | 03:20 PM
ttsupra94's Avatar
ttsupra94
275 has got to be too small for 11 wide rears. I was told that 275 was the ideal size for 9.5. WOW. Must just be really tight
Old Apr 4, 2004 | 03:44 PM
mr2fasterthanyo
steve-
i used them as my daily tire, and along with quite a few trips to the track, i got about 1500 miles out of them, then i sold the car and it still had about half of the tred left. i drove it really hard though even around town.
my 235's were on 8.5" rims so yes, 275 sounds too small for 11"
that would be some really tight sidewalls if you could even get them on there
Old Apr 4, 2004 | 03:57 PM
etx's Avatar
etx
Old Apr 4, 2004 | 09:12 PM
pinoy4065's Avatar
pinoy4065
ummm for my use would probably be mostly daily driven but given the fact that i drive hard still so of course something that still grips pretty well
Old Apr 4, 2004 | 10:21 PM
spazpilot's Avatar
spazpilot
Yep could but waiting for toyo to make a 295 which is in the works right now. As for fit here is some pics
Old Apr 4, 2004 | 10:22 PM
spazpilot's Avatar
spazpilot
pic two of my baby
Old Apr 4, 2004 | 11:26 PM
pinoy4065's Avatar
pinoy4065
interesting...NICE CAR!..are those HRE wheels?
Old Apr 4, 2004 | 11:41 PM
spazpilot's Avatar
spazpilot
yep 540r
Old Apr 5, 2004 | 07:02 AM
PoWeRtRiP's Avatar
PoWeRtRiP
--Steve
i run gforce ta drag radials as a daily tire! 265/40/18 on my stock rims. needed something that hooks good for the track. and they are not all that expensive, you can find a 275/40/18 for about 180 each. about half what you pay for a set of comparable longer lasting tires.
