VORTECH Important Info
Old Apr 3, 2004 | 04:11 PM
fluidz's Avatar
fluidz
Default VORTECH Important Info
OK guys, thxs to 12SecZ i have solved my problem..........after driving my car it ran great and then started to run and idle like sh*t, the problem was my intake came off my plenum, so i re-attached it and it still would not idle or run for more than 2 seconds..............the solution was as 12secZ said:
Per the RoadSide assistance from NISSAN manual turn the ignition key on 3 times within 5 seconds doing this resets the TPS in the ECU.
Car now starts,idles and runs perfect, thank you 12secZ
hope this info helps someone else down the road. Time to TUNE her.
PEAS!!!
FluidZ
Old Apr 3, 2004 | 04:18 PM
slay2k's Avatar
slay2k
It resets the TPS ? I hope that's not the tire pressure sensors ? heh!
Happy that u solved ur problem btw! Good luck!
Old Apr 3, 2004 | 04:46 PM
esemes's Avatar
esemes
congrats!!
i feel (even) better about my "near future" plans now.....
keep us posted on the numbers (with a/f specifically)
-eS
Old Apr 3, 2004 | 05:36 PM
fluidz's Avatar
fluidz
Originally posted by esemes
congrats!!
-eS
Here are the A/F from the SS Box directly from Vortech, NO TUNING WAS DONE.
fluidz's Avatar
fluidz
TPS = Throttle Position Sensor
Old Apr 3, 2004 | 05:48 PM
booger's Avatar
booger
Glad to hear you found the problem....Told you it would be some thing simple . Go get that thing tuned and post the results
Old Apr 3, 2004 | 06:24 PM
12SecZ's Avatar
12SecZ
God is good, just got back. I never thought for a second it wouldn't work out and it was something simple we were missing.
Right on Kevin, I'm very happy for you and I know you are very happy too.
Yeah anytime you mess with the TB you gotta do that 3 key trick I keep em all printed out in my glove box there is tons of them!
Old Apr 4, 2004 | 09:41 AM
basam350z's Avatar
basam350z
Default Re: VORTECH Important Info
Do you actually start the car, or just get the ACC position?
PEAS!!!
FluidZ
Old Apr 4, 2004 | 09:43 AM
fluidz's Avatar
fluidz
ACC Position only............3 times in 5 seconds
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
Tochigi_236
Sep 27, 2015 03:40 PM
