What would be better for the Z, a single turbo or Twin Turbo?
Originally posted by Diesel350
Also wouldn't the single Turbo make more power than the Twin Turbo for less money?
A twin Turbo system is the ideal configuration for a V6 engine and will generate the best torque and power possible.
Peter
APS
Plumbing the sides together would be nearly impossible, unless the hood were bumped up and the cross-over took the high road.
One issue with a single T on a V engine is that turbo's efficiency drops due to the poor heat coupling from the far bank's exhaust. The best efficiency is obtained when as much exhaust heat can be coupled from the exhaust ports into the the impeller inlet.
it depends on your goals honestly....there is not "better" IMHO, there is better for your application
There are quite a few single turbo 350Z's out there in the world right now....and the reasons behind them are numerous.
I agree with Peter thought that for driveability, the twin is the route to go.
Originally posted by ranger5oh
Someone tried, and failed. The engine compartment is too small. But yes, a single turbo will make more power than a twinny.
Peter
APS
Well, on a V configuration engine, the twin is the easiest to do. Guess the main reason that someone would want a single is for less parts to go wrong and lower price. Top Secret has proven that it can be done though, so it shows that none of our manufactors here dare to be different and make it work here, instead they produce 50 very similar twin turbo kits, lol.
IF that calls out all you guys producing the kits, so be it. Be different, fill a niche and make some money.
Peter
APS
Well, I am sure if I drove a single turbo then compared it to a well engineered TT, I would choose the TT.
How about we make them both well engineered. Just kidding, lol.
CARB means very little to me, and there are others who would agree with me of course. I know how inportant it is in Cali, but if Top Secret can run a single in japan, seems we could make one for here. There emissions requirements in Japan are pretty strict too. I know the TT is more complex, but I was just speaking in terms of the plumbing for the single turbo.
Peter, I understand your viewpoint, especially with your TT kit coming out soon. Your kit is nice, believe me, but you have a whole lot of competition. A single turbo has no competition in the US. NONE. Lag issues are always brought up, but lag isn't always a bad thing if you know how to control it.
It would be nice if we had a choice, that is my only point.
Kinda like McDonalds forcing us to only eat breakfast before 10:30. I want my pancakes for dinner.
How about we make them both well engineered. Just kidding, lol.CARB means very little to me, and there are others who would agree with me of course. I know how inportant it is in Cali, but if Top Secret can run a single in japan, seems we could make one for here. There emissions requirements in Japan are pretty strict too. I know the TT is more complex, but I was just speaking in terms of the plumbing for the single turbo.
There are good reason why every OEM V-engine turbo system use TTs, evn now in 2004.
It certainly isn't cheaper to implement TTs , but it does make a more street friendly setup (ie smaller , quicker spooling Turbos) and it make CARB possible. Not to imply that OEMs provide "fully optimal" solutions.
Now if your objective is pure offroad performance , no CARB, less TQ below ~4k not important ,then peak gains can be made better with a single large turbo. The main diff being that the efficiency island occurs at a higher flow volume with the single big T vs. two smaller Ts with islands lower down.
Yeah, G3po, really I was thinking along the lines of comparing a ST to a certifugal SC, only cause the cost could be similar if you add headers to the SC, with install for each one. The power curve for the ST would be more peaky than a TT, like you said, but you would have substantially more low end torque than a certifugal SC(which is also peaky). The ST and SC w/headers could be similar in price installed, with the ST putting up alot more power on the low end cause it can hit max boost so early. Depends on the price of the ST, of course. Just a thought.
I am interested to know why a single would make CARB so impossible to attain.
The reason why a single Turbo on an VQ would be difficult to meet CARB is that the excess heat loss in the "long cross pipes would not allow the CAT(s) to heat up rapidly enough and hence violate the CARB cold light up requirement. Also not that both CARS must remaoin intact which also causes a plumbing issue (1 Turbo branched to two CATs.
The light up requirement is one reason why all new autos place the CAT(s) as close as possible to the exhaust manifold. They need to get the exhaust heat as quickly and efficiently as possible to the CAT(s). Long pipes won't cut it.
They also have higher octane pump gas then we do...I think 98 or 102 at the pump isn't that sick?
bcoffee20
Nov 19, 2015 06:39 PM
