Apex'i S-AFC-II vs. AEM Wideband
Old Apr 18, 2004 | 12:27 PM
joshbrittain's Avatar
joshbrittain
Default Apex'i S-AFC-II vs. AEM Wideband
Ive decided to go with the polished Vortech kit and the Borla headers and TD exhaust. Now I just have to decide between the AEM Wideband and Apex'i Super AFC II. Normally I would just use the search to find out as much as I can about both, but it doesnt seem to be working. What are you guys using and how do you like it? Is the S-AFC as accurate? Do those of you that use the S-AFC use a separate boost gauge or just use the boost display on the unit?
Old Apr 18, 2004 | 12:31 PM
fluidz's Avatar
fluidz
AEM......
Old Apr 18, 2004 | 05:35 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
why do you need to decide between these 2 products - they do not remotely do the same thing.......
Old Apr 18, 2004 | 05:37 PM
5thgenluder's Avatar
5thgenluder
im pretty sure the safc doesnt display air to fuel ratio or boost. the safc is a tool used in conjunction with a boost gauge and afr gauge. the apex piece is used to better tune the system
Old Apr 18, 2004 | 06:09 PM
joshbrittain
According to the Apex'i site, the SAFC does display boost and allows you to adjust the fuel curve to tailor the A/F ratio. Am I misunderstanding something? What are the benefits of the AEM wideband vs a regular A/F gauge like the greddy?
Old Apr 18, 2004 | 06:22 PM
etx's Avatar
etx
The SAFC is a very over rated product. It does the same thing the greddy e-manage does, modifys the maf signal to the ecu. It's a terrible way to tune your car, it's a hack. Buy the AEM wideband so you can tune the car properly.
Old Apr 18, 2004 | 08:08 PM
was wesman's Avatar
was wesman
Hmm....
the two products do entirely different things. While the SAFC does allow you to fine tune af etc, it doesn't display it for you. You will need to be on a dyno,wideband etc. to be able to tune with it. The AEM on the other hand displays the AF but has no way of making adjustments, it's can data log, display the info (depending on which one you get).
If anything you would need them both....the AEM to display/monitor AF, the SAFC to tune it with those readings.
--wes
Old Apr 20, 2004 | 09:03 AM
Z1 Performance
Former Sponsor
was wesman has it right.....
The Apexi is not a hack, much in the same way an E Manage is not a hack - its far more user friendly than the E Manage for MOST people, though the E Manage is a far more capable unit.
Both can best be deemed as total self destruction boxes if being "tuned" by someone not familar with how either unit works, and how it does what it does.......
Best bet (I sound redundant now), is to speak with your intended tuner, and see what he is used to using.
Adam
Old Apr 20, 2004 | 09:06 AM
joshbrittain
Thanks for all the info, apparently I was getting some bad advice from one of the guys at a local shop. Ive just decided to go with Greddy boost and A/F gauges. Maybe later I'll try to tune it myself and get the SAFC.
Old Apr 20, 2004 | 03:37 PM
dollar99's Avatar
dollar99
the only reason I installed a s-afcII is to detect knock and also to save 2 preset fuel maps. One for 93 octane, or for race fuel. You can change from the two maps with a click of a button.
Old Apr 21, 2004 | 11:34 AM
Phatmitzu's Avatar
Phatmitzu
How do you tune the car with the AEM wideband?? Its a monitor, not a controller.
350Shadow
Sep 22, 2015 08:30 AM
Calinismo350z
Sep 14, 2015 04:04 PM
