my 400hp dyno run......
Old Apr 18, 2004 | 09:01 PM
tig488's Avatar
tig488
Default my 400hp dyno run......
.....was unsuccessful, some of you might remember my post about my first dyno after my vortech, i had a run where my hp numbers were up about 15-20, and my a/f was perfect, but at 4k rpms the system totally shut down, well come to find out some settings where causing the 2nd fuel pump not to come on, well a new dyno yesterday with correct settings yielded a good solid run, but the numbers werent what i expected, 400HP, instead it only hit 350, BUT the a/f is almost perfect, it hovers right between 11.8-12.0, its weird that the numbers were lower, but i guess im satisfied with a perfect a/f,
another weird thing is i tried enthuzds' fuel map where he got 393 hp, on my car it only got 350,
Old Apr 18, 2004 | 09:02 PM
tig488's Avatar
tig488
here is the corrected dyno run beside the run where the system was shutting off, you can see the higher hp numbers
Old Apr 19, 2004 | 05:20 AM
Baumer's Avatar
Baumer
I'd be happy with the results. I'd take engine longevity over an extra 20 hp anytime. You should see some extra power once you put the test pipes on. Are you getting the bumper on today? Great job on the coupe looks awesome!
Old Apr 19, 2004 | 05:42 AM
tig488's Avatar
tig488
thanks baumer, i do like the afr better now, im picking up the bumper today and should have some pics up tonight
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
