vortech install pricing
Old Apr 26, 2004 | 11:56 AM
pimprider2000's Avatar
pimprider2000
Default vortech install pricing
okay, I went to a performance center today, and they quoted me 2,100 for the instal of a vortech kit, JWT clutch & flywheel. This includes dyno tuni9ng and R4 programming.
Is this a good/reasonable deal?
thanks for any input!
Old Apr 26, 2004 | 01:03 PM
kzanard's Avatar
kzanard
That sounds a little high. I had Vortech and JWT combo installed (and tuned) for about $1500
Old Apr 26, 2004 | 01:30 PM
teh215's Avatar
teh215
I did it myself and it is very easy to do and very hard to screw up. If you have a few hand tools and are even semi-mechanically inclined, I would recommend doing it yourself and using the money you save to get something else...
Old Apr 26, 2004 | 02:21 PM
pimprider2000
i am an idiot , no seriously, I just don't trust myself to do this job yet( I am going back to school to learn mechanics). i would rather have a pro do it right now.
Old Apr 26, 2004 | 08:37 PM
fluidz's Avatar
fluidz
you get what you pay for most the time, I payed $1,200.00 for my install, included vortech, test pipes, pulley swap, gauges, and grill cut out removal and untuned dyno. I was charged 65.00 an hour, took 20 hours or so for everything..........car runs great no problems at all.
Old Apr 27, 2004 | 03:02 AM
teh215's Avatar
teh215
20 hours is about how long it took me to do everything and I loved every minute of it ...
Old Apr 27, 2004 | 05:08 AM
jpc350z's Avatar
jpc350z
Does the SC come with a set of good directions? Did you or will you have to do anything to the ECU? What was the most difficult part of the assembly? Thanks for sharing your experience..
Old Apr 27, 2004 | 05:56 AM
teh215's Avatar
teh215
The instructions are fairly thorough and easy to understand. The only part I can recall that is incorrect and required a little creative plumbing is connecting the BOV to the engine vacuum. The vacuum line on the engine is 1/8" ID and the BOV is 5/16" ID so I have to go buy an adapter. You do have to splice into the ECU for Crank position, MAF, cam timing, power and ground. The whole install really was not that difficult, just labor intensive.
Old Apr 27, 2004 | 11:03 AM
Forced's Avatar
Forced
jpc350z...
check this:
http://www.vortechsuperchargers.com/...s/4nz218im.pdf
Old Apr 27, 2004 | 05:41 PM
pimprider2000
Yet they said it would take around 30 hours, they charge 65 a hour, so I figured around 2,000-2,100. so if it doesn't take them that long, then it shouldn't cost me that much.
65 a hour is a normal rate right?
Old Apr 27, 2004 | 07:23 PM
zimbo's Avatar
zimbo
My installer charged $750 for the kit install and $500 for the R4 tuning. The Infiniti dealer charged $450 to install my clutch and flywheel. I consider those fees to be premium pricing, but I felt it was worth it in both cases due to the expertise/experience factor.
--Steve
Old Apr 27, 2004 | 08:26 PM
fluidz's Avatar
fluidz
$65.00 an hour in california is cheap for a good installer.
Old Apr 29, 2004 | 06:14 PM
booger's Avatar
booger
SCer install , plugs, and.3 gauges...18.5 hours... $1,321.00
Old May 2, 2004 | 07:33 PM
5thgenluder's Avatar
5thgenluder
those prices seem high
Old May 3, 2004 | 06:17 AM
BrianLG35C's Avatar
BrianLG35C
Where in Ohio are you exactly??
Obadabot
Jun 18, 2023 11:31 PM
