Vortech installed - problem
Old May 6, 2004 | 12:42 PM
igor@af's Avatar
igor@af
Default Vortech installed - problem
We installed the Vortech S/C yesterday (phew!) but the engine is throwing P0345 OBD-II Code.
P0345: Cam Angle Sensor ; 2nd Bank
Has anyone had a similar encounter?
Also, the car has tremendous difficulty starting - the crank rotates but the engine doesn't start... but eventually it does start.
Thanks guys.
Old May 6, 2004 | 12:45 PM
baptist's Avatar
baptist
Have you tried reseting the throttle position sensor. Fluidz had alot of problems starting his after install and it running dog rough.
The sequence is to turn the key to the ACC position 3 times within 5 seconds.
Worth ago mate.
Old May 6, 2004 | 01:15 PM
igor@af's Avatar
igor@af
Just tried with no success.
Also, while driving, the car seems to be in limp mode with little power.
Old May 6, 2004 | 01:23 PM
baptist's Avatar
baptist
Maybe Fluidz can help.
Hope mine is ok tomorrow.
I'm sure the guys on here will come up with something, some clever fellas.
Good luck mate, wish I could help more.
Old May 6, 2004 | 01:41 PM
fluidz's Avatar
fluidz
Sounds like the SS Box is installed incorrectly. There are a few cam sensor wires that probably are crossed or incorrectly wired. I would double check that first and if it dosent fix, disconnect the ss box and start, should be fine. I'd bet 50 bucks the ss box is not properly wired.
Old May 6, 2004 | 02:00 PM
2003z's Avatar
2003z
I'm not sure how their box works, but fluidz is probably right. It would be real easy to wire in the crank sensor splice backwards. My OCD got the best of me and I must have checked my wiring at least 8 times to make sure I didn't get anything backwards with the stillen.
Old May 6, 2004 | 04:50 PM
igor@af's Avatar
igor@af
is there any way to disable the ss box without cutting all of the wires?
Old May 6, 2004 | 07:10 PM
fluidz's Avatar
fluidz
nope...............
Old May 6, 2004 | 07:36 PM
igor@af's Avatar
igor@af
wish me luck! we're gonna take the ss box out of the circuit tomorrow.
Old May 7, 2004 | 05:28 AM
mcduck's Avatar
mcduck
Hmm... which cam is considered "Bank 2". I know that the Vortech sits incredibly close to one of the cam sensors where the supercharger mounts
It may be possible that the sensor was bumped or damaged somehow during install. I'd still go with the SS box check first. If not, you may want to run a diagnostic on that sensor.
If you have a service manual, you will find the cam sensor diagnostic procedures on pages EC308-EC315. Good luck!
Old May 7, 2004 | 01:47 PM
igor@af's Avatar
igor@af
The issue was the box itself. When we directed the CAM wire to go straight into the ECU without interception by the box the car started up fine and no more OBD-II codes.
Hopefully a replacement SS box will be here tomorrow.
Old May 8, 2004 | 01:20 PM
igor@af's Avatar
igor@af
The replacement SS box was just put in and everything works like a charm - it was indeed a defected SS box.
Old May 8, 2004 | 01:49 PM
baptist's Avatar
baptist
Glad to hear you've sorted it.
My kit is brilliant.
Found a small oil leak on the tee piece that comes off the oil pressure sender unit to the blower oil feed. Its just weeping out. Taking it back on Monday to sort it.
What a car this is with forced induction.
Old May 9, 2004 | 07:18 AM
igor@af's Avatar
igor@af
Incredible, isn't it?
Old May 15, 2004 | 11:17 AM
igor@af's Avatar
igor@af
The problem of the P0345 code came back about 3 days after the box was replaced.... very interesting.
Old Jan 19, 2006 | 12:06 PM
MCopare's Avatar
MCopare
Was this ever resolved? I have it now with the Vortech......getting codes
P0335 Crank Position sensor
P0345 Camshaft Position sensor
Any fixes?
Old May 11, 2008 | 07:57 PM
jvargas714's Avatar
jvargas714
i am having the same problem does anyone have any advice or has had a similar problem that could maybe help me out!!!!!!!! SES light with code P0345
Old May 12, 2008 | 04:28 AM
jpc350z's Avatar
jpc350z
You might nedd to provide more info for folks to help analyze to problem..Had the car run fine, how long , did you make any mods lately,the more info the better the diagnosis..
Old Sep 15, 2008 | 12:58 PM
ADMAN's Avatar
ADMAN
Any fixes?
Was any of this ever resolved???
Uriyo_
Sep 8, 2021 08:46 AM
