Am I using the right formula to figure out exhaust size area?
Old May 19, 2004 | 11:28 AM
bruschijr's Avatar
bruschijr
Default Am I using the right formula to figure out exhaust size area?
Im using the pi x r-squared formula to get area to see whats better... a 3.5 inch turbo pipe.... or a dual 2.5 from the cats back.... From ultimate racing... it seems the dual combined has a larger area so it would be better than the single pipe right? Am i doing this correctly?
Old May 19, 2004 | 03:03 PM
redva350z's Avatar
redva350z
yep, i dunno which is better but thats the right equation
Old May 19, 2004 | 10:41 PM
D'oh's Avatar
D'oh
I've always heard that for turbo's bigger is better.
(2.5/2)^2*pi*2 = 9.82
(3.5/2)^2*pi = 9.62
Overall the 2.5" has just a bit more total x-sectional area. However, if you look at the flow profile of a fluid in a tube, it will slow down near the surface and be the fastest in the center. Your 2.5" pipe has more surface and would therefore restrict the flow more than the 3.5". Since the two are so close in x-sectional area, I believe that the greater surface of the 2.5" would restrict the flow enough to overcome its slight increase in area and therefore cause a slightly greater restriction overall.
Therefore, the 3.5" would be better.
-D'oh!
liqalu04
Jan 2, 2022 12:58 PM
hulkout
Apr 28, 2017 09:00 PM
Justin100
Nov 29, 2015 03:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
