So my Z caught on FIRE...
Old May 28, 2004 | 10:01 PM
  #41
350Now's Avatar
350Now
Thanks for the info Charles. It should be the passenger side correct? I'm gonna have to wrap the starter in heat wrap so that non of the wires have contact outside.
Old May 28, 2004 | 11:57 PM
  #42
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I assume you mean Passenger side...the side with the starter. So if my starter and all the wiring is completey wrapped in hear-wrap, am I OK? Or do I still need to reclock.
Take a look...this is what I did to mine.
http://www.savepic.com/is.php?i=5347&img=IMG_2073.jpg
Old May 29, 2004 | 01:56 AM
  #43
phunk's Avatar
phunk
CJ Motorsports
GQ: Based on the pics it looks like what you did was a good idea. I dont imagine the starter having problems with the heat in the area... but definatly not a bad idea. With all the wrap on it is hard to see exactly where it would be contacting the closest, but as long as the power cable cant possible touch anything then you fine... to me it appears that you have plenty of clearance, but like i said its hard to tell thru all that wrap.
Just let it be known that the Greddy heat wrap is a very good conductor... and this is what caused my problem and the guy who started this thread.
But if you look at your pics, imagine that you rotated only the center part of the turbo so that the oil return pipe was further away from the starter... that is what I did to prevent further issues.
Old May 29, 2004 | 02:21 AM
  #44
phunk's Avatar
phunk
CJ Motorsports
the only thing i am seeing in that picture that has me at all concerned is the oil feed line...
being around these things for a long time, and seeing all kinds of ****... I think I should let all the people who are doing this install for themselves know... a stainless braided line like that oil feed line needs to be routed thoughtfully and secured carefully.
You might not think it at first, but a stainless braided line, over time, will saw thru just about any part of your car. I have seen stainless lines end up cutting thru AC pipes, brake pipes, wear thru valvecovers, etc. Keep on eye on what your stainless braided lines are in contact with.
When I post some pics to my thread I want to show you guys what I did with the oil feed lines for this kit, you might like it...
I find it pretty cool that you guys are doing self installs on this kit... althought I am very interested and would love to do the install for as many people as want to bring it to me... i cant help but cringe at the same time. so many things are so much easier to do... that install is pretty much the most tedious turbo system install I have had to do... ill have to ask chris how he compares it to the vipers.
-charles
Old May 29, 2004 | 08:54 PM
  #45
joenismo's Avatar
joenismo
On my installation we began to wrap the starter thinking this was a good idea, but the wrap began to arch and spark. We still had battery connected, I know should have disconnected in the beginning, but after the sparking incident we decided wrapping the starter with Greddy's heat wrapping material was not a good idea. As far as the oil return line, we just bent it out of the way. There is about 1/2 inch of clearance. Clocking the turbo is whole lot of work, you would have to remove the turbo.
Old May 31, 2004 | 07:16 AM
  #46
phile's Avatar
phile
Originally posted by accordfreak
sorry to hear that man..
another reason why i would NEVER let someone touch my car with a big job like that or any minor installs for that matter.
if you want it done right you just gotta give up your time and do it yourself. you'll learn a lot during the process too
goodluck
Easier said that done man. I have never worked on a car in my life. If you left me with a garage and a bunch of tools to install a Greddy kit on my Z, when you came back it would look like a dilapidated transformer.
Old May 31, 2004 | 08:32 AM
  #47
Bini2's Avatar
Bini2
Default Re: So my Z caught on FIRE...
Originally posted by slay2k
I get an email while on the cruise about some "colorful news" from ATX and that I am a "lucky puppy." On Monday, I find out my car caught on fire. Yeah, one of the wires/harnesses was not installed correctly and got wedged between the battery and the starter, which caused an electrical fire. This quickly converted into a grease fire... which thankfully they were able to put out without any major damage. I just had to get a new harness for about $150 and pay for the labor to reinstall it.
The guys at Z1 Motorsports looked at my car on Saturday. One of the wiring harnesses was too close to the + on the starter. I almost had a fire, some of the wires were black and were starting to scorche.
I feel your pain.
Boston350Z
Mar 18, 2003 01:50 PM
christurismohk
Oct 24, 2002 06:58 AM
rep15
Sep 4, 2002 10:04 PM
