Vortech with 9lb pulley over rev the blower
Old Jun 22, 2004 | 04:35 PM
booger's Avatar
booger
Default Vortech with 9lb pulley over rev the blower
I just found a calculator for rpm's of the blower..I put in the new # with the 3.125 jackshaft pulley .The rpm's of the blower go to over 60,000 at 6,800 engine rpm's . Max for the blower is 50,000 .If I am wrong correct me Please !!!!!
Old Jun 22, 2004 | 04:40 PM
2003z's Avatar
2003z
I believe in the latest 'best supercharger' thread (by xxsmallpaulxx, I think), that Forced, the vortech rep said 80000 rpm is the max for it.
Old Jun 22, 2004 | 04:49 PM
booger's Avatar
booger
I may have read it wrong..but I got the link for the calculator from a thread that Foeced posted a reply to and he said it was 50,000 rpms .I'll check the thread you are talking about .And I'll think I'll check Vortech's web site
Old Jun 22, 2004 | 05:04 PM
zimbo's Avatar
zimbo
I think your calculations are wrong. I think it puts you at around 54000 and the reported max is 53000 (with optimal performance being at 50000) although Forced stated that you could go higher than that.
--Steve
Old Jun 22, 2004 | 05:24 PM
booger's Avatar
booger
--Steve
I put in the calculator [provided by Force ] 5.73 in. crankshaft pulley ....28 teeth SC cog pulley...32 teeth jackshaft cog pulley....3.12 inch serp pulley...shift point...6,800rpm...and IT came up with....over 60,000rpms
Old Jun 22, 2004 | 05:49 PM
zimbo's Avatar
zimbo
Well if that's the case then it's going to boost over 10 psi. My recollection is that when I plugged in the numbers for the regular jackshaft pulley and a 34-tooth cog pulley I got 54000 at 7000 rpms. I see about 10psi with that configuration.
--Steve
Old Jun 22, 2004 | 05:57 PM
booger's Avatar
booger
--Steve
Im going to take it easy on it untill I can get to the tuner on the 9th of July .I will see then and let you know .Thinking of upgrading the bearings this coming winter
Old Jun 22, 2004 | 06:26 PM
esemes's Avatar
esemes
is the 34 tooth cogger stock???
also, if you do bearing upgardes (did it on my v1, MUCH better) i suggest getting the shell polished.... thas what i wanna have done!!
below is a pic of mine, after a few good wipes of mothers al. polish..... (gave up shortly thereafter)
Old Jun 22, 2004 | 06:40 PM
esemes's Avatar
esemes
pic.........
Attached Thumbnails Vortech with 9lb pulley over rev the blower-homegrownpolish1.jpg
Old Jun 22, 2004 | 06:42 PM
esemes's Avatar
esemes
closer.........
(excuse the crappy pix!)
note: see the score-mark i use for the blower belt??? this is the pint at which it is too tight (and causes excessive compressor noise)
not the best look, but effective!
-eS
Attached Thumbnails Vortech with 9lb pulley over rev the blower-homegrownpolish2.jpg
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Calinismo350z
Sep 14, 2015 04:04 PM
