upping the ante...... vortech style
Old Jun 30, 2004 | 06:47 PM
zimbo's Avatar
zimbo
esemes, YGPM.
--Steve
Old Jun 30, 2004 | 07:21 PM
tig488's Avatar
tig488
Default Re: pully
Originally posted by booger
You have to take off the adjuster pully and cog belt . Losen up the top three bolts holding the blower to the bracket . Take off the bolt holding serp pully on . Pry over the blower far enough to get the serp pully off . Not hard . Pm me if you need to know any thing else...Bill
what about the pulley retainer assembly, do i need to buy one of these kits fo 8$ or do i not need it?
Old Jul 1, 2004 | 06:56 AM
booger's Avatar
booger
Default Re: Re: pully
Not sure what your talking about.....the pulley is kept from turning by a [dont know what they call them] metal piece about an inch long , it has a slot that you slide it into after you put the pulley on . Then you bolt it down . Nothing needed but the pulley it self
Old Jul 1, 2004 | 07:38 AM
OldManZ350's Avatar
OldManZ350
Its called a Key and Keyway
Old Jul 1, 2004 | 07:46 AM
booger's Avatar
booger
yes that it KEY
Old Jul 1, 2004 | 09:36 AM
esemes's Avatar
esemes
the jackshaft bolthead on my new pulley seems to have a slight (very) warble to it.////
it seems tight, but it cant be good that it's not spinning true (conversely, the pulley body behind the bolt IS spinning true....
help??
Old Jul 1, 2004 | 12:31 PM
tig488's Avatar
tig488
if you go the the vortech website, and click on the pulley, and click on more info, it states that the pulley retainer assembly is required for installation, i figured i didnt need it.
Old Jul 1, 2004 | 02:38 PM
esemes's Avatar
esemes
new info::
seems there's ever-so-slightly a pulse (and i mean slight... you havat know to look for it!!) with the key and this pulley.... its jus a RCH amount of tolerance between the groove and the key...
the good news is that the pulley spins true as it gets.....
i retensioned the gilmer belt guide, and found that makes a HUGE difference in compressor sound....
i dont think it's supposed to be very tensioned (beyond just pushing down on it evenly, then tightened), as the entire assembly (and BOV, subsequently) is MUCH MUCH quieter than if i leaned hard on the tensiuoner before tightening....
does this make any sense?? hope so...
anyway, the ECU seems to have awakened, and all i can say now is
HOLY SH#T!!!! the new pulley makes this thing pull ALOT harder (ALL thru the lower rpm's) than the oem pulley...
granted, im not going above 4-5lbs of boost until im remapped, but anyway..... its NIGHT and DAY....... i feel like the car just lost 800 lbs of weight....
no joke....
bring on the dyno... bring it on!!
Old Jul 1, 2004 | 03:00 PM
booger's Avatar
booger
Originally posted by esemes
new info::
no joke....
told ya
Old Jul 1, 2004 | 04:10 PM
booger's Avatar
booger
new info::
no joke....
Scott..got your phone message.....did you find out what you needed to know ?
Old Jul 1, 2004 | 04:57 PM
esemes's Avatar
esemes
prob solved
i think
350Z_Al
Oct 29, 2020 07:44 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
Calinismo350z
Sep 14, 2015 04:04 PM
