Nismo has now snapped.
Old Jun 30, 2004 | 11:35 AM
baptist's Avatar
baptist
Angry Nismo has now snapped.
As you may have read from my earlier posts, the Nismo exhaust had started to crack around the flange on the centre section of the exhuast. I got this welded up and refitted yesterday. Well, driving back from the gym today and it clean snapped in half near the new weld. AAAAAAAARRRGH!!!
I just cant work out what is stressing this system so much.
Old Jun 30, 2004 | 02:06 PM
teh215's Avatar
teh215
Any pics of the failed weld?
Old Jun 30, 2004 | 02:21 PM
baptist's Avatar
baptist
It turned out to start at the weld then move away from it. The tubing itself actually snapped. I havent had the car up on the ramps as it only happened tonight, but the whole pipe has snapped off now.
Old Jun 30, 2004 | 02:25 PM
APS's Avatar
APS
Default Re: Nismo has now snapped.
Hey sorry to hear of the problem with exhaust..............have a look on the APS web site...............look closely at the exhaust system..............this will give you an idea as to why your exhaust is suffering from fatique.
Peter
Old Jun 30, 2004 | 02:47 PM
baptist's Avatar
baptist
Not really with you there Peter????
Has anyone else suffered like I have with an exhaust, in particular Nismo failing???
Old Jun 30, 2004 | 03:11 PM
APS's Avatar
APS
Mate I believe that you need flexible couplings in the exhaust system............like we have in the APS cat back exhaust...........this helps to reduce the stress on the exhaust system............hope this helps.
Peter
APS
Old Jun 30, 2004 | 04:41 PM
was wesman's Avatar
was wesman
Peter
APS
Doesn't really help him....his ***** still broken
What's up with all the thread whoring going on these days with the salesman ?
--wes
Old Jun 30, 2004 | 04:56 PM
mpowers's Avatar
mpowers
Did you have problems with aftermarket cats as well at one point? Almost seems like a broken motor mount allowing the engine to twist too much. I have had decent luck with my Nismo exhaust. I have even snagged the exhasut on a trailer which keep the car from rolling off even at a step angle. I would also belive it should be warranty even with the blower.
esemes's Avatar
esemes
sorry to hear this mate
i know the LAST thing you wanna do is to have to spend more money, but... it'd be a safe bet to swap out the Y pipe (i think thas the one you talking about) for the FUJI Y pipe instead. It has the flex-pipe to it (with braiided coverings) so as to help prevent stress on the joints...
heres my fuji Y pipe (they are the makers of the nismo, so it should fit, hopefully)
Old Jul 1, 2004 | 02:53 AM
baptist's Avatar
baptist
This is the thing, the Nismo has the flexible joints in the Y pipe exactly like the one above. My engine mountings are definately okay.
The problem I had with the cats was to do with the brace that runs across the middle and links the cats together. The kinetix cats have the bracket welded directly to the outside wall of the cat and not onto a load bearing pad as it should be. In the end it just ripped the bracket clean off the cat.
Old Jul 1, 2004 | 02:55 AM
esemes's Avatar
esemes
baptist-
i need to see pics then.... im lost (i have cats that have flat tabs welded to them, and the crossbrace matches up to them.....)
lets see, if you can
sms
Old Jul 1, 2004 | 03:01 AM
baptist's Avatar
baptist
This has happened to a friend also with the Nismo and kinetix cats (he doesnt have the Vortech).
His tabs also started to break away from the cats and then snapped off. He ended up taking the cats off the car and removing the tabs, welding the hole up and putting them back on the car.
I cant see how this is causing a problem further down the system as the flexible joints are downstream of the cats and provide adequate movement for the system.
Does this make sense Esemes?
Spoke to Kinetix and they are aware of the problem and are now welding the tabs onto a pad which is welded onto the cat wall.
Old Jul 1, 2004 | 03:09 AM
esemes's Avatar
esemes
aha!!
so when the tab failed, it actually left an opening in the wall of the cat (by design of the nounting tab)....
look at this mount next, tell me your thoughts
is it different, or am i doomed to have a failure?? (In YO)
Old Jul 1, 2004 | 03:44 AM
baptist's Avatar
baptist
Thats a different design cat (crawford?) so you will probably be ok. The wall on the Kinetix cats was very thin, I thought.
Is it a double skin on those cats??
Old Jul 1, 2004 | 08:39 AM
mpowers's Avatar
mpowers
esemes the nismo comes with that exact flex pipe. It might be residual from the cats/bracket problem. Still should be covered under warranty baptist.
Old Jul 1, 2004 | 03:31 PM
spf4000's Avatar
spf4000
I had the same problem with my right cat, but it was a stock one. The bracket that attaches the cat to the brace cracked and was rattling like crazy until I got it replaced. I have the Nismo Exhaust on it as well. Maybe the exhaust was torqued down too much?
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
