I have a Question About FI
Hey guys whats up. Ive recently been looking at Forced Induction and I have a few questions that couldnt be answered by searching. At least i didnt find nething.
I know by doing forced induction that it will depreciate the life of the motor. But ive always had the impression from what i have heard on other car sites that SC allows the life of your engine to be longer than a TC. So Im looking at the ATI Procharger and the Greddy TT. Both are nice setups with FMIC and all the goodies. But how is the ATI Procharger on the Engine when compared to the Greddy TT ??? Will my engine last me longer if I were to go with the Procharger as opposed to the Greddy TT ?? They are both pretty comprable in price i believe after tuning and all that good stuff.
So what do you guys suggest? How reliable is the Procharger in comparison to the TT kit and will my engine last longer for me with the Procharger ??? Thank you in advance and any help would be greatly appreciated !!!
The Greddy, on average will be about $2000 more than a comparable Vortech kit, and maybe $1000 more than the ATI, since the ATI doesnt come with timing retard provisions (unless they changed something recently).
In terms of engine reliability, there is a general consensus on the boards that TUNING is the deciding factor on engine life, not SC vs. TT, or a particular brand. When properly tuned, and running reasonable boost levels, engine reliability should be the same for both kits. Any poorly tuned (pinging...running too lean), F/I setup with destory a motor very quickly.
Good luck!
Good luck!
heres the only logical difference i really could come up with to satisfy your question.
with the TT setup you hit peak boost before redline wich naturally causes more crancase pressures throughout the rpm range as opposed to the SC setup where boost is peaked at your highest rev rpm( centrifugal style that is). a TC setup is more equivelant to a roots style SC as you get peak boost before redline. the SC builds boost from engine rpm due to crank revolutions whereas the TC builds boost off of the exhaust. is there any real downfall here? no, it really depends where you want you want your power to peak.
now, with the SC setup there is more strain on the main bearings since the crank is responsible for providing rotation to the SC. since the belt needs to be fairly tight & the new crank pulley is sticks out further than the factory crank, excessive pressure is applied to the crank wich results in more stress on the main bearings. the extended crank pulley & tight belt works like leverage pulling to one side in the crank where a TC does not.
there are downfalls to each setup & i dont believe either would extend engine life as higher crankcase pressures are more detrimental than not having extra pressure on the internals. both take hp to make hp so they are equivalent in that aspect. the beauty of both setups is that you can drive less aggressively & maintain decent gas mileage yet the power is there with the stomping of the gas unlike serious n/a setups where different cam profiles effect your gas mileage weather your idling or really getting on it..............theres so much more areas to touch on but we'd be here all day. im sure ill strike up some arguments now between the hardcore SC & TC lovers. hope this helped....
-justin
-justin
One thing that I feel that alot of people leave out of these types of threads is driving habits. If you leave ever stop sign with tires blazin' and run it up to redline consistently, do not expect to see 150,000 miles on the motor. I very rarely get into boost on my motor unless the mood strikes me or I need to. This is one thing that I like about a SC, I can control when I am in boost. Just my 2¢.
I personally agree with your thoughts myz8a4re.
There are some that will disagree but the turbo runs slightly hotter and produces slightly more power/torque than a (cent.) S/C like the ATI or vortech kit. For those reasons alone it would only make sense that the TT will be harder on your cars engine and drive train. Especailly for a car that didn't have a trubo in mind when it was produced (weak rods, weak pistons, high compression, etc). This is why I chose the ATI S/C.
This is not to say that a poorly tuned S/C will not blow a motor. That is the biggest problem we have had with the 350Z. In fact, as many will point out the ATI S/C has blown several engines, more so than any other form of F/I. However, on the counter side of this. All but one or two of those blown motors were tuned by the same shop that had serious issues with timing and A/F ratios.
well, here's my .02
Superchargers only put pressure and minimal heat on the intake charge, however, Turbos put pressure on exhaust and intake charges with significantly more heat introduced (exhaust heat). This is also part of what causes Turbos to produce such incredible power associated with them.
Unless you're going to rebuild your head with better valves/springs/retainers soon to increase reliability ( say nothing of rods/pistons etc) then I would go SC. If you care only about max power all the time from about 3500 +, then rebuild your head, do some internal work, and play with boost all day long
