9lb pulley installed
Old Jul 19, 2004 | 07:45 AM
mcduck's Avatar
mcduck
Guys... I'm really leaning toward ordering the 34-tooth and the 3.12" serpentine pulleys today.
My big concern would be the impending "KABOOM" if they are not tuned for properly. I desperately need to know if I can cap boost at 9lbs... does the software/blow off do that for me?
I want to get to my 420-425hp faster, but not necessarily go higher. Thoughts? I'm thinking the stock injectors would not keep up with higher boost then 9lbs anyway...
Old Jul 19, 2004 | 07:56 AM
UsafaRice's Avatar
UsafaRice
One more from the 300zx days. There was a little thing called a pop-off valve attached to the intake manifold. It had a spring in it and released any intake pressure over 8.5 psi. I don't think the vortech bov or bypasses are designed for something like this. Unfortunately, this is one of the things a turbo's wastegate is much better in. You could always pulls timing and add fuel past the 9 psi mark and reduce power that way.
Fixxxercask
Nov 9, 2015 11:10 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
