Upgrading the Vortech Intercooler
Old Jul 24, 2004 | 02:52 PM
g35twinturbo's Avatar
g35twinturbo
Arrow Upgrading the Vortech Intercooler
I have seen a few pics of the vortech intercooler, and it is very small compared to the greddy and pro charger intercooler.
Could one upgrade the intercooler?
What would the pros and cons be, by doing this.
I know the greddy intercooler requires a diffrent location of the air bag sensor in the front bumper but, if i were to go with a larger intercooler that came with the vortech would that be beneficial?
Thanks
Jordan
Old Jul 24, 2004 | 03:05 PM
teh215's Avatar
teh215
I have thought about this but since it was designed as part of the system, why would you need to?
Old Jul 24, 2004 | 03:20 PM
g35twinturbo
i was thinking maby just to increase cooling if i were to ever increase boost with a new pully, also i think it just looks beter.
Old Jul 24, 2004 | 03:41 PM
JimRHIT's Avatar
JimRHIT
sure it would look better ... but in the case of the G35c ... you would be better off with a JWT TT style dual intercooler setup, both performance and looks
Old Jul 24, 2004 | 05:24 PM
esemes's Avatar
esemes
a bigger FMIC would offer less boost (not much, but some, i have read), and possibly increase creep (again, per readings)
i think the best thing to do is to have an open passageway to it, to maximize effeciency of it...
bigger aint better in this case...
(although a big dual inlet honker looks the part!!, IMO)
Old Jul 24, 2004 | 07:37 PM
whosdady's Avatar
whosdady
A bigger I/C will only be necessary (or help) if you increase boost presssure from the standard 8PSI kit. I have heard the guys producing 9+ PSI are producing less effiecint boost, meaning the amount of HP per PSI actually goes down. For example on the ATI kit each PSI represents roughly 20rwhp. With the vortech kit it is closer to 15rwhp and as you go over 9 PSI it goes closer to 10rwhp per PSI.
I agree with JRITT, a different bumper or jwt IC setup would be perfect for the G35.
Old Jul 24, 2004 | 09:02 PM
esemes's Avatar
esemes
whosdady-
who told you this about the less efficient boost??
this sounds very specifically aimed at the 9+ vortech guys, so im wondering which (of us) has determined this, and relayed it to you.
i also couldnt find any real world data (user dyno's)to substantiate your "for example" math showing ati to be dominant (surprise ) over vortech...
it looks like one pound of boost (per your advertisement) nets a RWlb-ft TQ gain of 45 for you..... somehow, i find that to be too good to be true... i guess if you dont pull timing out, you can acheive any numbers... but the longevity of this , well, i dont wanna make any guesses there...
that said, my vortech expereinces have NOT shown less efficient boost, but rather MUCH better midrange gains and a marginal upper gain too (netted ~20rwhp on my 333 to 312 swapout)....
Old Jul 24, 2004 | 09:04 PM
g35twinturbo
thanks for your insight esemes. u really know your stuff, are u sure u dont work for nasa or somthin.
Old Jul 25, 2004 | 01:09 PM
whosdady's Avatar
whosdady
Originally posted by esemes
whosdady-
If you understand why we have IC's on FI cars, then you would understand that at a certain point an IC becomes too small for the application. (compressor puts out air, it is hot, the IC cools it down and enhances the efficiency of the compressor) In the case of voertech, the IC is too small for the compressor at 9+ lbs of boost. The result is less efficiency and thus less HP.
I learned this from someone that tested both the ATI IC and the vortech IC. Yes timing does have something to do with this. But for the most part ATI is able to provide more efficent HP for two reasons. 1) Higher impeller redline: It doesn't work as hard 2: The IC is bigger and is able to keep the air cooler: more efficient.
Old Jul 25, 2004 | 03:02 PM
esemes's Avatar
esemes
i give up....
Old Jul 25, 2004 | 10:30 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
i give up....
350Z_Al
Oct 29, 2020 07:44 PM
