Can you do this Vortech Pulley swap?
Old Jul 28, 2004 | 06:19 AM
mcduck's Avatar
mcduck
Default Can you do this Vortech Pulley swap?
okay... don't flame me... this may not even be feasible, but I'm not at home where I can just go to my garage to look at my engine.
In a pulley drive set up, the general rule is ... the larger the drive pulley, the faster the idler pulley will spin and/or the smaller the idler pulley, the faster it will spin. I'm talking about belt travel, not actual rotational velocity which stays constant.
So, to get your SC to spin quicker on the Vortech, everyone has been looking at placing a smaller serpentine pulley (idler pulley) or a larger cogged pulley (drive pulley).
Okay... let's say, I replace the cogged 32-tooth pulley with the 34-tooth pulley. I will see gains... this has been proven by Zimbo and a couple of others here. Has anyone looked at replacing the pulley on the actual supercharger (cogged idler pulley) with a smaller cogged pulley? Is there a smaller cogged pulley even available?
Old Jul 28, 2004 | 07:13 AM
booger's Avatar
booger
Yes I would guess they have smaller SC pulleys .The reason we changed the serp pulley was to keep the warranty .But Vortech knows about it now and they drop it to 1 year . Unless you buy it from another source [Grubb's ] but you will pay extra for it . The serp pulley is the easiest to change out . To get the 3.33 serp off , you need to losen up the top 3 bolt that hold the blower to the bracket . Pry the blower over far enough to slip the pulley off .You will need to go to a 93 inch belt also . Yes you will see gains from either pulley you choose to go with . Blower will spool up faster and boost will also go up at the top end . I gained extra boost across the whole rpm range.............Bill
Old Jul 28, 2004 | 10:08 AM
mcduck's Avatar
mcduck
Thanks, booger... I actually found that there is a 27-tooth that is a replacement for the 28-tooth on the Supercharger itself.
mcduck is now thinking the fall HP project may include a three pulley swap... mix in some bottom end... and see if the Vortech can crank out close to 1 bar of boost! WOOHOO!!!
Old Jul 28, 2004 | 10:29 AM
esemes's Avatar
esemes
MC duck is a wise man....
MC duck also needs to find/manufacture a n external wastegate, to relieve the near 17 lbs of boost down to a 12 lb charge....
this would allow MC duck to have the excellent advantages of esemes insta-spool® (lol) and still keep the valvecovers from shooting thru the hood....
i am SURE there's a way to fab. an inline wastegate, so you could run MUCH more efficeint pulleys, and still bleed-off unwanted charges (could be very similar to the BOV, and could be welded into the intake line, somewhere before the MAF i suppose)
if i were still a vortech man, that'd be my NEXT situatiuon.....
NTM, anyone running well over ~9 lbs of boost oughtta look at the vortech MONDO BOV, as it has a higher rating (lbs).....
so sez the birdie.........
Old Jul 29, 2004 | 08:21 PM
Houston G35's Avatar
Houston G35
Go for it Mcduck,
Take the plunge. I will be right behind you and so will many others. Your mission is to go boldly, where no man has gone before.
If you wait to long, you will be beat out by me or a few others.
Just do it!!
Old Jul 30, 2004 | 07:36 AM
greddy4777's Avatar
greddy4777
you guys don't kno me....
but i luv you guys....hahaha
can't wait to read about it!!
i wonder what Vortech is saying about Mcduck at the moments...lol
Old Jul 30, 2004 | 03:35 PM
mcduck's Avatar
mcduck
2 of the 3 pulleys arrived this week.... muhahahahahah.... MUHAHAHAHAHAHA!!!!!
Old Jul 30, 2004 | 04:18 PM
esemes's Avatar
esemes
way to go, your boostfulness!!
(bows down)
S
Old Jul 30, 2004 | 07:24 PM
booger's Avatar
booger
I got my 2.87 yesterday ...Hey Scott Im pretty sure I can get the 92.6 belt on with this pulley . As I almost was able to get it on with the 3.125 .Let us know how you turn out Mcduck
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
SharX59
Sep 27, 2015 09:23 AM
Calinismo350z
Sep 14, 2015 04:04 PM
