Profec & AEM wideband problem
Old Aug 15, 2004 | 04:53 PM
zimbo's Avatar
zimbo
Default Profec & AEM wideband problem
For whatever reason, when I use the external signal harness with the Greddy Profec E-01 and the voltage table provided by the AEM Wideband O2 installation instructions, the lowest A/F ratio that the Profec reports is 11.2.
The AEM installation instructions show something like this:
11.00 = 0.500
11.25 = 0.625
11.50 = 0.750
16.75 = 3.375
So I have the Profec programmed to be 10.00 at 0v up to 16.75 at 3.375 volts. However, as stated above, the lowest I see is 11.2 on the Profec even when the A/F level is pegged below 11.0 on the gauge itself.
I'm pretty sure others (Sharif?) have said that they are able to see values below 11.0 on the Profec so perhaps something is wrong on my end.
Any ideas?
--Steve
Old Aug 15, 2004 | 05:30 PM
joenismo's Avatar
joenismo
When you are datalogging A/F from the AEM gauge onto the profec E-01 there are a couple of things to remember. The AEM gauge is a non-linear graph, and the E-01 can only show a linear graph. So you can only be accurate between a certain ranges of A/F. Mostly between 10.5-13 (or something like that I can't remember exactly). I do not remember the numbers I entered on the profec to graph the A/F from the aem. If you don't get the correct figures tonight I can post mine tomorrow.
Old Aug 15, 2004 | 07:29 PM
zimbo's Avatar
zimbo
I would love it if someone would post the numbers. On my instructions (page 9 of the AEM install guide), the numbers look pretty darn linear, i.e. exactly 0.125 for every 0.25 AFR from 11.00 to 16.75.
--Steve
Old Aug 15, 2004 | 07:47 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I did the scaling on the PROFEC and it matches perfectly...across the board. I dont know how or why...but it works perfectly.
You need to use the other page of values zimbo. I think it's like 0 volts is 9.7AF and 5volts is 17.9. Dont quote me on those numbers...they are not exactly accurate. But there is another page of conversion values in the instruction book...use those...not the ones you are refering to. I wish I had my car back from the shop, so I could read the values right off the Profec.
Hth,
Sharif
Old Aug 15, 2004 | 07:54 PM
zimbo's Avatar
zimbo
Dang!
I have the instruction manual right here in front of me and there's only one chart showing values. It's on page 9, right beneath a graph showing AFR versus Lambda. The odd thing is that when I go WOT, the analog value (reading the voltage of the white wire from the AEM gauge) drops down to 0.525 or something like that by about 4000 rpms and stays there until redline when I am pretty darn sure my A/F isn't *exactly* 11.2 from 4000 rpms to 7000 rpms.
The rest of the time, the AFR numbers on the Profec seem to correspond pretty closely to the numbers on the AEM gauge itself.
--Steve
Old Aug 16, 2004 | 07:14 AM
Sharif@Forged
Forged Performance
So what is the coversion factor that you used.
0 Volts = ?
5 Volts = ?
Old Aug 28, 2004 | 01:10 AM
03_ppw350z's Avatar
03_ppw350z
anyone anser gq here? im curious as well
Old Aug 29, 2004 | 02:59 PM
KPierson's Avatar
KPierson
I would love to know the answer as well. If I ever get the AEM wideband I ordered 2 months ago I'm going to build an analog alarm circuit to let me know when my A/F is too lean, since my guage will be mounted out of sight. I would hate to blow up another engine.....
Kevin
www.KPtechnologies.net
Old Aug 29, 2004 | 03:17 PM
zimbo's Avatar
zimbo
Well, after much testing I decided to use 0.525 volts as 11.00 and then go in 0.125 volt increments per 0.25 of A/F. Something like that. The Profec and the gauge itself are always within 0.1 of each other (though it's hard to sweep my eyes immediately from one to the other).
--Steve
Old Aug 29, 2004 | 06:00 PM
gspot35's Avatar
gspot35
Default Lean Alarm
You will reconsider that Kevin, as every time your car is decelerating you will hear that alarm unless you enable the alarm only if you have positive boost via engine management.
Kevin
Old Aug 29, 2004 | 06:08 PM
KPierson's Avatar
KPierson
Default Re: Lean Alarm
I was thinking for of a visual alarm, like two 3mm LED mounted in the Apillar. I know it won't be perfect, but under WOT I can monitor them and under normal circumstances I can ignore them. The boost sense is a good idea. I should have bought an electronic boost guage instead of a mechanical.
Kevin
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
