Arias Pistons Pics Here
Old Aug 20, 2004 | 12:33 PM
Zcool's Avatar
Zcool
Default Arias Pistons Pics Here
For those who got in on the Arias Pistons group buy mine arrived yesterday (8.5:1 CR). Here are some pics. 1:
Old Aug 20, 2004 | 12:34 PM
Zcool's Avatar
Zcool
pic 2:
Old Aug 20, 2004 | 12:35 PM
Zcool's Avatar
Zcool
pic 3:
Old Aug 20, 2004 | 12:51 PM
tig488's Avatar
tig488
its so prettay!
Old Aug 20, 2004 | 01:02 PM
axxizzer's Avatar
axxizzer
do they make an 11:1?
Old Aug 20, 2004 | 03:02 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I love it...i love it....i love it. It's like Christmas time all over again!. Thanks for sharing Zcool.
Axxizzer, Arias can make them in any compression you desire. PM me if you are interested in buying some.
Old Aug 20, 2004 | 03:14 PM
luanda's Avatar
luanda
Very nice...
I can't wait to hear from you guys about how these and the Pauter rods run - noticeable difference if any in daily driveability of your engines yada yada yada....
Old Aug 20, 2004 | 03:40 PM
IceY2K1Max's Avatar
IceY2K1Max
Almost too pretty to install...almost.
Old Aug 20, 2004 | 03:42 PM
IceY2K1Max's Avatar
IceY2K1Max
Also, aren't there wrist pin clips included?
Old Aug 20, 2004 | 04:32 PM
bigern1970's Avatar
bigern1970
I guarantee you he is sleeping with hose under his pillow.lol . Were total seal rings offered with those pistons......thanks
Old Aug 20, 2004 | 04:38 PM
bigern1970's Avatar
bigern1970
I know you didnt start the thread GQ but are these .020 over ? if not how much over, is .030 or .040 over still consider a clean up bore will these require honing or will the block need to be punched out more,is everybody in the GB getting the same size bore?
sorry if it seems like a jack
Old Aug 20, 2004 | 04:58 PM
G3po's Avatar
G3po
Default overbore
They are standard bore, two people went this way and thus received their pistons earlier. The rest of the 8.5:1 guys went with .020. Any more overbore with OEM sleeves is not recommended.
Old Aug 20, 2004 | 05:25 PM
Sharif@Forged
Forged Performance
^^^what he said^^
With the GB, you had a choice of compression, and a choice of standard bore, or a .020 overbore. They can make them any way that you want. If you want additional overbore, they can do that too, but as G3 mentioned, I wouldnt trust the stock sleeves if your goal is to increase displacement by overboring. .020 is done primarliy to clean up the cylinder wall, and allow for a perfect initial seal between pistons rings and cylinder.
The pistons set includes pistons, rings, wrist pins, and locks...everything you need to install them.
Old Aug 21, 2004 | 08:36 AM
Chebosto's Avatar
Chebosto
are you going to heat treat them, or do they already come treated ?
Old Aug 21, 2004 | 08:49 PM
Jergens's Avatar
Jergens
Oh my god I am pissed I missed on this... GRHHH! Those look gorgeous guys.
~Josh
Old Aug 21, 2004 | 09:00 PM
supra crazy's Avatar
supra crazy
This may be a dumb question but what is overbore?
is it increasing the serface area of the pistons?
Old Aug 23, 2004 | 05:56 AM
Sharif@Forged
Forged Performance
.020 overbore is just a slighly...and I mean....very slighty larger diameter piston. A .020 overbore is used so the machine shop can perfect the bore shape...since the cylinder bore will become slightly oval shaped due to the natural forces of the motor. So we bore it .020 before putting the piston in. This way, you get a perfect seal. It's debatable if .020 is really necessary in newer motors in good condition, but its likely a good idea. Oh, and the strenth of the cylinder wall is not materially effected, since we are taking away material that is roughly 1 human hair's thickness.
Cheston, heat treatments are optional...roughly $120 for the set of pistons. Again...also debatable as to how effective they are. Some people swear by them, others say they are a waste of money. More important is the piston design, materials used, and the assmebly/machining of the motor.
Jergen, PM me if you are interested in pistons...I can help.
Old Aug 23, 2004 | 10:34 PM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
whats the best compression rates for a greddy TT kit? Cause I was thinkin about buying that myself and Tomei Cams.
Old Aug 24, 2004 | 05:10 AM
Sharif@Forged
Forged Performance
In the Group Buy I did, the TT people went with 8.5:1 to 9.1:1
I dont think there is really a "best" CR. It depends on your goals, and on the turbos. The PE's would probably be better matched at about 9.5:1, whereas the Greddy's becuase you need to boost more to get them in their sweet-spot, would likely work better in the 8.5 - 9.0 range.
If the goal is 600whp plus, I would go 8.5:1, and if the goal is mid 500 level, then I'd choose 9.0:1 Hope that helps!
Old Aug 24, 2004 | 08:38 AM
phile's Avatar
phile
how mch does it cost to install new rods and pistons?
