ATI Cog belt pulley install ??
Old Aug 23, 2004 | 11:31 AM
was wesman's Avatar
was wesman
Default ATI Cog belt pulley install ??
I finally got my new belt, and frankly, I'm not sure how to install it. I have the manual but it isn't real clear on how to install this belt, but clearly outlines the other two belts.
Any tips on install of the SC cog belt on the rear of the unit ???
--wes
Old Aug 23, 2004 | 03:34 PM
was wesman's Avatar
was wesman
Any of the self installers wanna help me out??? I need boost back...had a neck/neck run with a WRX today....that just aint right.
--wes
Old Aug 23, 2004 | 03:44 PM
mprowe350's Avatar
mprowe350
Wes,
You have to loosen but not remove the smaller allen bolts that allow you to turn the pully shaft housing. These are located on the front and are attached into the slotted parts. Then take the top most rear pully apart by loosening the small allen bolts on the pully itself. With the front three allen bolts loosen but not removed try to rotate the pully shaft housing and remove the belt. Same to put it back on. PM me for further info.
MIKE
Old Aug 24, 2004 | 03:25 PM
was wesman's Avatar
was wesman
belt is on and boost is good...thanks man.
Had a little trouble with one of the allen head bolts....turns out one was stripped...that took some doing but we're all good now.
BOOOOOOOSSSTTTT!!!
--wes
Old Aug 24, 2004 | 03:51 PM
Happyending's Avatar
Happyending
Tore up the rear cog belt??Aint it a biatch!!
Fixxxercask
Nov 9, 2015 11:10 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
