The car is RUNNING on the HKS FCON VPRO and HKS 1000cc Injectors
Old Sep 3, 2004 | 05:10 PM
phunk's Avatar
phunk
CJ Motorsports
BTW im running 9 psi now on the dyno. im here in the office letting it cool down. I am gonna stop here I think... the car is pulling so ****in hard on the dyno that its got me scared being that its a stock motor. Really freaking me out right now. I am gonna do one more 9psi pass after it cools down then 9psi is just for the track or a worthy race. I am gonna keep it at 7.5 or 8psi for daily driving like i was doing on the E-Manage.
Old Sep 3, 2004 | 05:23 PM
IceY2K1Max's Avatar
IceY2K1Max
Where are the charts man?
Or at least what are the peak tq and hp numbers at 9psi?
Old Sep 3, 2004 | 05:31 PM
phunk's Avatar
phunk
CJ Motorsports
well... 8.5psi was 461rwhp and 433lb ft.
Ill get you the 9 psi and the graph shortly.
-Charles
Old Sep 3, 2004 | 05:34 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
a road trip maybe in order once the new heads are on my car ...the FCON would make a nice b day present from the wife
Old Sep 3, 2004 | 05:37 PM
Juztin's Avatar
Juztin
holy cow, that's insane numbers! Im not sure if you mentioned this Charles, but are you pulling timing with the VPRO or still letting it go ***** to the walls?
Old Sep 3, 2004 | 06:06 PM
phunk's Avatar
phunk
CJ Motorsports
if someone wants to host my 9 psi dyno graph let me know... my server is still messed up.
Juztin: the FCON is a standalone therefore it does not even consider the factory timing maps, you have to build your own from scratch. I am running about 22 degrees of timing.
Old Sep 3, 2004 | 06:29 PM
phunk's Avatar
phunk
CJ Motorsports
well i dunno... i cant host it right now so ill post it later when i can.
Its easily the cleanest FI 350z dyno graph in existence.
Old Sep 3, 2004 | 08:52 PM
IceY2K1Max's Avatar
IceY2K1Max
phunk,
Just go upload it to cardomain.com and then link it over here. You'll lose a bit of quality/size, but it's usually still readable.
Old Sep 4, 2004 | 12:17 AM
AmyCroft's Avatar
AmyCroft
Smile Follow up - Smooth - Zero Smoothing
CJM:
Yes - what a difference... We have Zero Smoothing Dyno results with the GTT and Dynojet.. the Up and Down Jitter was very noticable.. GQ at 377Hp months ago... At Reseda Dyno Day..
Smoothing for a "good" read was set to three.. Just to get numbers.
We read your link at.. Smooooth
https://my350z.com/forum/showthread....threadid=90212
With Zero Smoothing and very awsum numbers.. It appears the
E-Manage is the culprit.. An the limit on the Maximum HP..
Yes - Charles you have found the "Hot Setup" - Maf input problems aside.. ( VDC,TCS Cruise )
Congradulations... Please keep "Tuner Notes" of your findings..
P.S. Don't blow the stock engine.. It's only as stong as it's weakest point.. The Skinny Rods...
Cheers Amy -
P.S.2 - the Street Film at 8PSI.. was helpful.. One can hear the
Blow Off Valve - Ticking at shift.. Very Cool..
Old Sep 4, 2004 | 08:57 AM
350Now's Avatar
350Now
wow amazing # Charles. this is with C16 right.. the HKS FCON sounds very promising.
Old Sep 4, 2004 | 09:10 AM
phunk's Avatar
phunk
CJ Motorsports
no this is not on C16. This was done with 100 octane fuel, and I will probably start running 93 octane in it now that I have the tunability I want.
Old Sep 4, 2004 | 04:10 PM
G3po's Avatar
G3po
Default Sans Power Writer
Originally posted by Z1 Performance
being that its full standalone you can have an endless array of maps stored on your laptop and download as needed. Thts one of the beautiful things about standalone. I have had the Electromotive on my 280 ZX for years now....I easily have 100+ maps stored on my laptop for different gas, boost levels, humidity levels, etc etc.
Phunk - can you run without sensor feedback ? IE - no input from the knock or 02 sensors and just run the raw map you have programmed? What is the resolution?
I guess I should re-phrase my question. Can these maps be downloaded "without" the full Power Writer application? For example is there a simple "map-flash" utility that any user can access?
Old Sep 5, 2004 | 10:29 AM
DIGItonium's Avatar
DIGItonium
Whoa... I'm going to back to tweaking the computer for more speed. I don't think I can do that with my car... it'll be like an early 4th of July Celebration! :-P
Old Nov 28, 2004 | 07:48 AM
techz33's Avatar
techz33
Default what year is your car
Old Nov 28, 2004 | 11:46 AM
mchapman's Avatar
mchapman
Where are the supra race videos?
pslamp32
Feb 8, 2017 09:07 AM
Bodyboarder81
Nov 2, 2015 12:17 AM
z33z_nutz
Sep 23, 2015 07:22 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
