No one talks about stillen here are some dyno's
Talked to stillen on friday about my belt problem and explained could it possibly be the tension arm .
Colin stated that it is possible since i have gone through my last belt in less than 300 miles.
Colin stated he would send me a new tension arm with a new belt again it was friday about 4pm so he said he would send it overnite on monday morning, I also stated i wasn't getting 7psi on my stage three we talked about what i was running with the SC Colin told me i could be loosing approx 1/2lb loss with the kinetix cats so he asked if he could get back to me on Monday morning i said sure.
Monday morning about 10am Colin called said he would send me a different pulley to solve my boost problem.
Tuesday afternoon my pkg arrived installed the new tension arm new belt and new pulley the boost is excellent now just have to wait and see on the belt problem..
I got great service from both Adam and Colin at stillen.....
I really don't see how cats sould make a difference on boost pressure. I mean you are generating boost pressure into the plenum and from there into the cylinders. After the combustion stroke you are then exhausting spent gases into headers/manifold, etc... Cats are so far away from how much boost pressure you are running. What kind of guage are using?
Ok, it makes more sense now. I only have one word though, Damn. That is one loose valve train. I know this thread started out for a 'simple' bolt on, but I think with some head work and a nice valve job, cams, forged guts I think the stillen could be a viable killing machine. One question though, why would someone build a valvetrain that loose?
Originally posted by bascelik
Heck, I'd put a Paxton.... or some other twin screw SC on this thing. Screw roots...
FYI, the only TS manufaturers are Magnussun and Autorotor.
KB integrates Autorotor units.
If every body bugged KenneBell enough they may change their tune. I tried a few times already.
So Stillen sent you a pulley with a little higer boost to compensate for you having cats?
Originally posted by 350_Z
Mediq,
Mediq,
ps.
Still trying to get conformation on what the output of the new pulley is should hear something today....
Okay, so your runnin 308RWHP on a stage 3? Now Stillen "clames" that the stage one, non-aftercooled SC pushes 305RWHP while the stage 3 hits 339RWHP. Why arn't you gettin those results expecally with the ammount of mods you have done?
I was looking into the stage 1 due to the fact that I don't have very much money at the moment and I only want 350RWHP max anyways. Vortec and Procharger seem to produce more power, with a better kit, at the same ammount of money as the Stillen Stage 3. Not to mention your belt problems, i haven't heard of Vortec or Procharger having any problems at all besides the motor not being able to handel the boost.
Now my question here is what are my options for running a 100% safe 350RWHP motor here? SC with the right fuel upgrades and a 13 AF ratio? Keep in mind my money budget is about 5000K for now but i can get parts as I go, once I start working more again. What does everyone suggest?
I have a Vortech....I had headers , no cats and could only make 7.6psi on a 9lb pulley . I put on crawford cats and now have 9.5psi . Making the same WHP with 7.6psi and 9.5psi . So more flow is alway good......more noise.....but good
I don't know if they sent me a compensatory pulley for the hiflow cats or not but I'm now getting 7psi without problem. gonna re dyno soon...
ps.
ps.
