Toasted my fuel injectors
Old Sep 7, 2004 | 06:25 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
That's the whole flaw of the design. I imagine they are running at 100% duty cycle very quicly...and then couple that with 90psi of pressure is just a recipe for failure. Sounds like your seals were leaking, and the IS a result of too much pressure....no question about that.
Yes, I've seen many cars running 100psi of pressure, but its not ideal at all. It is a workaround. The correct theory is to get an injector that is big enough to work at 80% duty cycle at a reasonable 50-60psi of pressure, and a fuel system that can supply the fuel at those levels. That is the way to go.
Old Sep 7, 2004 | 06:38 PM
IceY2K1Max's Avatar
IceY2K1Max
Mounting hole?
You mean the o-ring that seals between the injector and the lower intake manifold?
Originally posted by dfw350z
The seals on the injectors where they meet the mounting hole were leaking. That is why I am replacing them.
Old Sep 7, 2004 | 08:09 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Originally posted by Mike@Altered
Ed,
When people are refering to "380cc reflash" they are most likely talking about the Technosquare flash program for the PE 380cc injectors.
You have a custom AAM flash for your ATI Procharger/440cc injectors/AAM Return Fuel System. The program is similar to the flash I made for my 350Z with the 7psi ATI Procherger/440cc injectors/AAM fuel system, with minor adjustments made on the dyno for your pulley upgrade and your particular car.
Hope this helps,
That's what I thought Mike. Thanks for the clarification.
Old Sep 7, 2004 | 09:08 PM
AmyCroft's Avatar
AmyCroft
Default Save Your Old Injectors.. They Can Be tested..
Are you saying Your Injectors are "BLown" because
1. No FPR
2. Leaking at O-Rings Because of No FPR and Inline Pump?
DFW - I don't know exactly what to say... Nothing..
Old Sep 7, 2004 | 09:39 PM
whosdady's Avatar
whosdady
I'm glad to see that several vortech guys are reading this thread... I am trying to hold back from saying.... I told you...
Now do you believe me about the stock fuel pump and stock injectors? If you plan on running more than 8 psi on the this kit, it is much safer to upgrade injectors and the fuel pump. Will it work without doing this? Yes. Will it work longer than a few months? Probably not.
Lets hope there was no other damage to this car from bad injectors.
Old Sep 7, 2004 | 11:15 PM
tig488's Avatar
tig488
hmm, 1 person so far, im not worried.
Old Sep 8, 2004 | 07:10 AM
whosdady's Avatar
whosdady
He wont be the last... It was kind of like the blown motor epidemic we had this summer, right before the forged internal group buy. Z and G owners started boosting a little higher and several engines bit the dust in mid august after a couple months of high boosting enjoyment.
I can't understand why some people don't see this (stock injectors and stock fuel pump) as a ticking time bomb. I would be pretty concerned if this happened to someone already. Just wait until it gets a little colder outside and you hit 9+psi...
Old Sep 8, 2004 | 07:39 AM
IceY2K1Max's Avatar
IceY2K1Max
Like I've said, it's not the fuel pressure. We(Maximas) have been running these DEKA injectors, since 2000 withOUT any reported issues.
I suspect he's having a seal problem, which DOES happen pretty often when people run high manifold pressures and the seals aren't properly installed.
If he does an impedance check on the "bad" injectors and that's fine, I'd send one or two prime canidates for $14/each to http://www.ptrsds.com/injectservice.html to be tested.
I still call BS, but he could just have bad luck....I guess.
tig488's Avatar
tig488
so what do you think will happen when it gets colder and it hits 9psi? please explain before it gets cold!
Old Sep 8, 2004 | 08:28 AM
IceY2K1Max's Avatar
IceY2K1Max
I'm not sure what cold has to do with leaking injectors, however at 380rwhp level, he needs larger injectors as people have been saying.
Right now with 90psi fuel pressure, optimistic BSFC=.50, and all 290cc's, he's on the verge of the injectors going static.
He would not be wise to reinstall stock sized injectors. I just don't think what his installer is calling "bad injectors" is what I'd call bad.
Old Sep 8, 2004 | 09:00 AM
tig488's Avatar
tig488
so for those of us running stock injectors with the vortech hitting near 9-9.5 psi, what injectors would you recommend installing, the PE 380s, or 440s?
Old Sep 8, 2004 | 09:19 AM
IceY2K1Max's Avatar
IceY2K1Max
PE 510s....and stock fuel pressure.
380s wouldn't be worthwhile IMO. Your fuel pressure and/or duty cycle will still be high.
440s will be fine/good, but you'll need to boost fuel pressure a bit to keep recommended "safe" duty cycle.
I like stock fuel pressure, because it's stable, easy to tune, and easy on injectors and you don't need a booster pump or FPR.
The only reason people choose PE380s is for the TS convienence, otherwise 510s and 500bhp is safe and leaves room to grow.
Old Sep 8, 2004 | 01:55 PM
tig488's Avatar
tig488
510s damn, and the factory ones are ~300? thats quite a jump,
so if im using the ss fuel/timing box, and i get some 510s, how do i know the box will be able to control the injectors, with the 510s i guess the box will have to "hold back" the higher injectors.
Old Sep 8, 2004 | 02:07 PM
dfw350z's Avatar
dfw350z
I would go with my setup of 440 low impedance injectors. Grubbs has already tested this configuration with the G35 + SS box and everything works fine.
Old Sep 8, 2004 | 02:10 PM
whosdady's Avatar
whosdady
510's are too much for those running 10 psi or less with a supercharger. It will not work unless you have the emanage. Many guys with turbos running 550+rwhp have them but they are running a lot more boost. I had 720's with my supra...
Initially I felt the RC 440's would be a good compromise but chose the 380's. If I had a turbo and was going to run more than 10psi I would have gone with the 440's.
As far as the cold weather... You will be happy to note your supercharger will be more efficient and will feel much stronger in the cold weather. That being said, there will be more stress on the injectors to keep up with the added efficiency.
Old Sep 8, 2004 | 02:20 PM
IceY2K1Max's Avatar
IceY2K1Max
287bhp-->500bhp~~74% jump
290cc---->510cc~~~76% jump
eManage can control them, so should the SS-box. You'll just need to adjust the whole fuel map by X% vs. the eManage automatically subtracting X% for you.
I'm not sure what you mean by "hold back", because other then at idle, it won't be an issue.
Old Sep 8, 2004 | 02:21 PM
IceY2K1Max's Avatar
IceY2K1Max
You mean high impedance, right?
Old Sep 8, 2004 | 02:30 PM
  #38
tig488's Avatar
tig488
what i mean is that with the factory injectors the ss box is adding more fuel than taking so if i add bigger injectors more fuel will be going in, so ill have to rely on the ss box to "hold back" more fuel so the car wont run pig rich all the time. i just dont know if the ss box can do that.
Old Sep 8, 2004 | 02:40 PM
  #39
IceY2K1Max's Avatar
IceY2K1Max
That's also because you're using an aux fuel pump and "washer" to ramp up fuel pressure per boost.
With stock fuel pressure, you'll be adding fuel, but hopefully not past the 80% duty cycle point.
There are more then one way to skin a cat here:
1)290cc + HIGH fuel pressure increase.
2)380cc + Medium fuel pressure increase.
3)440cc + Low fuel pressure increase.
4)510cc + STOCK fuel pressure.
Old Sep 8, 2004 | 02:49 PM
  #40
tig488's Avatar
tig488
when you say "washer"? you mean?
