Vortech 9lb pulley??
Old Sep 14, 2004 | 01:22 PM
booger's Avatar
booger
the 3.12....9.5psi...the only thing I gained is a quieter car . got the same whp as 7.6psi and no cats . Put crawford cats on ....got 9.5psi and the same whp after tuning
Old Sep 14, 2004 | 01:24 PM
daddyz's Avatar
daddyz
What is the part # on the 34 tooth jack shaft pulley? Mcduck?
Old Sep 15, 2004 | 07:03 AM
mcduck's Avatar
mcduck
booger...
Most have been getting the same rwhp or very close with the pulley change, but have been seeing the power come on earlier (for example peaking at 5500rpm instead of 6300rpm). Is this the case with yours? I really don't want more power since I'm already over 400rwhp. What I want is more total area under the curve. Can you post before and after dynos?
daddyz...
The vortech 34 tooth part number is 2A032-034. Keep in mind this is also a 50mm thick pulley instead of 35mm. Shouldn't affect the belt you use, but you will need a longer jackshaft bolt. And, you need to be sure to monitor how close the edge of the pulley comes to your intake pipe. I know on the G35 setup it runs very close. On the Z, we have a little more room so it should be okay.
Old Sep 15, 2004 | 07:21 AM
booger's Avatar
booger
My dynoes.....ended up looking exactly the same . Although my A/F was richer down low with the ...9.5psi and crawford cat dyno . I was thinking about that yesterday . Looking at both , I noticed my A/F didnt drop under 12 till after 4,500 rpm with the no cat dyno...and now its dropping below 12 at 3,600rpm . If I would have noticed it when I retuned I would have leaned it up some down low . I do feel like it does come on sooner .But with an auto.....you cant really see it on the dyno...In manual mode , in 3rd gear , you cant just floor it as soon as you shift . You have to gradually get into it or it will down shift into 2nd . So once it gets passed 3,500rpm , I can go WOT and not before then
Old Oct 8, 2004 | 11:15 AM
enthuzd's Avatar
enthuzd
This was/is a very helpful thread!
If I just change to the 3.12 serp pulley do I need to change the belt? If so, can someone provide the part number for the belt?
Thanks very much gentlemen.
One additional question. I read that when you change engine oil you're suppose to clean out some little filter on the Vortech oil line. Can one of you guys point out where this is? I would assume it is where the pan tap is...
Thanks again.
Stuart
Old Oct 8, 2004 | 11:22 AM
booger's Avatar
booger
Thanks again.
Stuart
The belt you need to go to is a Gates belt...#K060930 6PK2364............The oil screen you want to clean is... just before the nozzle on the oil feed line going to the blower
Old Oct 13, 2004 | 09:26 AM
daddyz's Avatar
daddyz
Where did you buy the belt? I called around nobody has them (pepboys,autozone,and oreilly's)And the part #K060930?Or6pk2364? This is for the 3.12 pulley?
Thanks,
Jayson
Old Oct 13, 2004 | 11:11 AM
booger's Avatar
booger
yup thats for the 3.12 pulley . Thats what I got on my car right now .I got it at O'Really's Auto Parts . Use the first # when asking for it .But both #'s are on the sleeve that it comes in . Napa has belts to fit....there belts are made by Gates . Just ask for a 6 rib micro-v belt....93 inches long
Old Oct 15, 2004 | 08:45 PM
daddyz's Avatar
daddyz
Cool thanks for the info!
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
seagrasser
Oct 11, 2015 03:27 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
Calinismo350z
Sep 14, 2015 04:04 PM
