BAD DAY! - PE TT, blew the engine at 5.7 psi
Old Sep 23, 2004 | 09:58 AM
  #61
G3po's Avatar
G3po
Default root cause
Originally posted by shivak
Whatever happened to the thread where we compiled information on all the blown FI motors? I guess there isn't as much interest in compiling this sort of data considering:
  • So many people are getting their motors built anyway.
  • It's pretty clear that the factory con rods are weak under boost.
  • The 2005 Anniversary / Track Z is most likely going to come with stronger con rods.
getting to a root cause of many of the bent/broken rod scenarios is pretty important even for those re-building with forged internals. If (pure conjecture) at this point there is a pre-ignition issue , forged rods can also be readily bent or broken. The only real solution to pre-ignition (if it is discovered) is elimination of the the root cause.
Old Sep 23, 2004 | 10:14 AM
  #62
etx's Avatar
etx
Originally posted by phunk
ravaz: those EGTs you are posting are insanely low... that couldnt possibly be taken from the manifold? is that in the downpipe?
EGTs that low (in the manifold) would be sign of a LOT of ignition timing (advance) combined with a LOT of fuel (rich as hell) and probably some high octane fuel as well??
I was about to say the same thing. Those EGT's are strange. You must have your thermocouple in the downpipe. My Z runs at about 700*-750*C in 6th on the freeway, under boost it stays at about 700*C due to the fuel enrichment.
My eclipse runs at 1600*F @ 25 psi on a biiiig turbo. 1600*F is about 870*C!
Old Sep 23, 2004 | 10:38 AM
  #63
ihatethatbobbarker's Avatar
ihatethatbobbarker
this makes me sad for you gurgen. hope it works out better in the future.
Old Sep 23, 2004 | 10:48 AM
  #64
GurgenPB's Avatar
GurgenPB
UltimateSleeper
yeah ... thanks
Old Sep 23, 2004 | 11:05 AM
  #65
G3po's Avatar
G3po
Default TSB
Originally posted by gurgenpb01
yeah ... thanks
FYI, check to see if your VIN falls under the Infiniti Crank sensor TSB. It oculd cause intermittent operation and maybe even pre-ignition.
Old Sep 23, 2004 | 03:34 PM
  #66
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Pre-ignition would almost instantly destory a motor even without F/I. I guess that is where I am confused. I don't see N/A motors blowing up. Maybe the high cylinder pressure has something to do with confusing this sensor???
  #67
IceY2K1Max's Avatar
IceY2K1Max
Gurgen,
Do you fall under this recall and if so, have you had it performed yet?
http://www.infiniti.com/form/0,,acti...,00.html#32902
2003 G35 Sedan Engine Sensors
Applies to 2003 G35 Sedan with the following Vehicle Identification Number range:
JNKCV****3M 000030 – 021207
The number of G35 vehicles potentially affected is approximately 19,102.
Old Sep 23, 2004 | 04:17 PM
  #68
GurgenPB's Avatar
GurgenPB
UltimateSleeper
yeah... I did
And I took care of the TSB (crank and cam position sensors) almost as soon as it came out
Old Sep 23, 2004 | 04:24 PM
  #69
KyleB's Avatar
KyleB
More pressure = more heat
more heat = more likely to pre-ignite
If the engine was run at it's highest output for a few seconds too long with extremely high pressure, it could've heated the spark plug to glow plug status and pre-ignited.
Will have pics of the damage soon (spark plugs, pistons, etc)?
Old Sep 23, 2004 | 08:01 PM
  #70
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Let's hope....
Old Sep 24, 2004 | 08:19 AM
  #71
Sharif@Forged
Forged Performance
I understand that. But what we're talking about is the potential for a faulty or defective sensor....not the normal progression of pre-ignition.
Old Sep 24, 2004 | 10:38 AM
  #72
KyleB's Avatar
KyleB
Definately possible. He already had the recall done, but Nissan has had problems in the past of letting defective parts get out into inventory as well. On my old spec v, I had the fuel sending unit replaced due to hard starts. I still had the same problem, the tech said that the FSU was bad. So they replaced my defective part with a defective part (3rd FSU worked great, no more probs).
Old Sep 24, 2004 | 12:33 PM
  #73
GurgenPB's Avatar
GurgenPB
UltimateSleeper
If this sensor is my problem..... talk about bad luck huh.... after all this, a $50 sensor brings the car down...
apex locator
Jul 23, 2021 02:27 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
