My Buildup Progress..
Old Sep 20, 2004 | 11:50 PM
03_ppw350z's Avatar
03_ppw350z
Default My Buildup Progress..
ok i was asked to start a thread about my engine buildup and how everything is going so here it is. first off let me say that all labor was done by myslef this includes building the engine installing everything. the only thing i did not do on my own was gap my rings and balance the assembly i had a local machine shop do it. the whole actual building of the engine and putting everything on the car took me 1 week.
the only thing i have done to the actual internals was just put the arias pistons which are stock bore size and 8.5 compression. and the pauter rods which are the ones everyone has gone with. the heads were not touched and i put the stock cams back in. i was on a tight budget so i decided i was not gonna do tha top end till myabee later down the line. so pretty much all i have is rods and pistons. now the fuel system is what everyone else uses also. i have aeromtive fuel regulator returned back to the top of the fuel pump assembly. i also epoxied the stock one so it doesnt do anything any more. i have my fuel pressure set at 50psi and its a 1:1 regulator so it rises under boost. i also have the walbro 255 high pressure pump in there. i still have the stock greddy injectors which are 440cc and the stock emange file that comes with the greddy. i also have the technosqare reflash to cover the timing. i had all this done when i was running the stock block. well thats really all that in the car. oh the transmission is stock 6 speed with a spec stage 3 clutch(holding very well!) everything else in the drivline is stock including the suspension. i have run 12 psi on pump gas for a few weeks now with the stock greddy map and 440cc injectors and my a/f stays at 10.98-11.1 it never goes above that. im thinking becuase of the 1:1 ratio of the regulator and the fact that i have 8.5 compression now is alowing me to boost this high with the 440cc. ive gone to the track already with 3 boost settings on 10psi my car went 11.6@122 on 12psi it went 11.4@125 and i put 103 octane in it to try and squeeze more boost out of it but it didnt work out i did hit 13.6 psi which gave me 11.6@127 as you can tell i have run 11.6 with only 10psi my problem is traction i have et streets and they still spin even at 12psi of tire pressure. best 60ft i have cut is 1.78 i plan on going to a 27 inch quik time pro so that can get the traction and not have to shift into 5th at the end of the track likei do now. they say for every inch of tire you can run 12mph more in each gear. i should be able to cross the traps in 4th. that is basicly it. very minor modifictions have been done and the car is runnning very strong. wait till i get those bigger injectors and actually tune the car!!
Old Sep 21, 2004 | 01:14 AM
RQ1Driver's Avatar
RQ1Driver
Default Re: My Buildup Progress..
Can we get some pics of the engine buildup? Thanks , Ken
Old Sep 21, 2004 | 06:04 AM
Enron Exec's Avatar
Enron Exec
And thanx for writing this up at 3 AM too!
Old Sep 21, 2004 | 07:22 AM
Chi-TownWarrior's Avatar
Chi-TownWarrior
Please post pics
Old Sep 21, 2004 | 11:06 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Couple of quick questions.
How do the pistons sound on a cold start? Any increase in noise?
How does the engine sound when it's fully warmed up?
Have you dynoed yet? If so....what was the power?
Hows does the low end and part throttle and full throttle repsonse feel? same as stock? Or slightly worser? Or much worse?
Thanks!!!
Old Sep 21, 2004 | 04:26 PM
350Now's Avatar
350Now
Great to hear Alfred on your build up. Get that beast on a dyno and see what's it's pushing out now. Pics as well if you have them.
TIA
Old Sep 21, 2004 | 08:06 PM
03_ppw350z's Avatar
03_ppw350z
ok i have not dynoed it and i wont till i get my bigger injectors and ttune it. the turbos do feel like they lag a little bit more but once they kick in hold on buddy. my pistons are a little nioser than stock not that bad the engine still purs it really quiet. my part throttle and low throttle feel the same to me as stock i didnt take any pics of the engine build i was to busy building the engine lol. i was trying to get it done in a week which i accomplished!
Old Sep 22, 2004 | 05:22 PM
Juztin's Avatar
Juztin
damn dude nice work in such short time, keep up the power bump
Old Sep 22, 2004 | 05:38 PM
IceY2K1Max's Avatar
IceY2K1Max
HOOOOOOLY ****....can't wait to see some more Z's in the 10s.
Old Sep 22, 2004 | 06:01 PM
03_ppw350z's Avatar
03_ppw350z
wait till i bump it to 20-22 psi.......
Old Sep 22, 2004 | 06:33 PM
Enron Exec's Avatar
Enron Exec
Dude, id drive over from Houston to see u dyno man! Much props to you on your accomplishments.
Old Sep 22, 2004 | 08:29 PM
Sharif@Forged
Forged Performance
I cant believe you did the buildup in your garage. Nice work.
What did you gap your compression ring at?
Old Sep 24, 2004 | 10:15 PM
accordfreak's Avatar
accordfreak
how about some pictures?
05UltraYellow
Sep 24, 2015 05:41 AM
SweetDreamZ
Oct 30, 2007 05:17 AM
Sharif@Forged
Shop Builds
60
Sep 13, 2007 07:37 AM
tranZition
Cleaning & Detailing
Oct 5, 2002 06:48 PM
