Need injector scaling help!
Old Sep 21, 2004 | 11:18 AM
zimbo's Avatar
zimbo
Default Need injector scaling help!
I have E-Manage and the Technosquare ECU reflash for the PE 380cc injectors. I just replaced the 380cc injectors with RC 650s and I've done the "injector scaling" thing with E-Manage.
The car idles fine and I have yet to see a Check Engine light, but the car doesn't run very well. It's sorta shaky and jerky if I give any throttle at all--and the A/F is still too low. Pretty much undriveable.
It looks like my Injector duty is pretty much already at 0% when this happens so I'm not sure if I can scale back the fuel any further.
Any ideas?
--Steve
Old Sep 21, 2004 | 11:23 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
you may need to significantly lean out your entire map. Is it shaky at part throttle? Or is is still shaky and WOT?
I assume you scaled from 380cc to 650cc..
If its still not working...try scaling from 280cc to 650cc.
Old Sep 21, 2004 | 11:26 AM
ravaz's Avatar
ravaz
Steve. I can hook you up with a fuel map if you want for the 650's. I made one up. Drives just fine but is slightly rich at idle, like right below 14. Let me know.
Old Sep 21, 2004 | 12:06 PM
zimbo's Avatar
zimbo
Bill, I may indeed need your help.
It's shaky at part throttle at low RPMs. I haven't dared to really gun it hard, to be honest.
I've tried messing around with the scaling. Right now it's set for 380cc to 650cc scaling since I have the PE reflash.
Another thing I'm noticing is that my A/F at idle varies widely depending upon whether or not the A/C and/or radiator fan is on.
I might be idling at 13.0 and if I turn on the A/C it will jump up to like 16.5. I don't know if it will settle back down because I immediately turned off the A/C because I was worried about doing damage.
Dang, I'm way too paranoid to have this as a hobby
--Steve
Old Sep 21, 2004 | 12:46 PM
ravaz's Avatar
ravaz
Steve, you got my # still right? Give me a buzz I'll help you out.
