Lean Idle with AC off
Old Sep 23, 2004 | 06:02 AM
CaneZMD's Avatar
CaneZMD
Default Lean Idle with AC off
Since I've had the Vortech, my Z idles rough and a little lean with the A/C off. So I've just left the AC on all the time, but this week, it seems like when the compressor turns off, the idle drops to about 900 and it starts running lean like 15-16 A/F. As soon as I blip the throttle, it goes back to normal.
Any suggestions on how to fix this? (other than a TS reflash to raise the idle RPM)
Old Sep 23, 2004 | 07:37 AM
dfw350z's Avatar
dfw350z
Default Vortech
I had a similar situation occur in my G35c with Vortech.
1. You can play with the R4 software and change the numbers by: (.1) at 500 and 1000 rpm across the board, it helped me.
2. I found out that my Fuel injector seals (#5 & #6) were leaking and needed to be replaced. I went with RC550 injectors and used the SS software to scale the fuel rates.
Old Sep 23, 2004 | 10:31 AM
CaneZMD's Avatar
CaneZMD
Hey dfw350z, how is that working with the rc550s and the r4 software? did you get a ts reflash? you should post the r4 map.
How did you get from lean idle to injector seal leaks? My af is right on at 14.6-15.0 cruising, and it's only at idle with the compressor off that it gets up that high. What I'm asking, is what made you look for injector seal leaks?
Old Sep 23, 2004 | 11:21 AM
booger's Avatar
booger
Default Re: Vortech
DFM350Z....We have been waiting to see if you got the new injectors to work with the R4........No replies ???? CaneDMD you car idles at 900rpm ? Seems high to me...mine is like 600rpm with a smooth 14.8 A/F
Old Sep 23, 2004 | 01:12 PM
dfw350z's Avatar
dfw350z
My idle problem...
My car was idling very strangely, like you very rough and up and down on AF. Then my dealer saw that my injector seals were bad on 5 and 6. Until the swap RC550 we were able to compensate with R4 software. "Check your seals" As you know were are pushing the factory injectors to 100+ duty cycle"
Old Sep 23, 2004 | 01:15 PM
dfw350z's Avatar
dfw350z
Default Re: Re: Vortech
Booger - Sorry please see my latest post:
Here is the BAD news
http://g35driver.com/forums/showflat...sed&sb=5&part=
The good news is things should work out fine with R4 and RC550's. I will post mapA and mapB once complete.
Old Sep 23, 2004 | 01:24 PM
booger's Avatar
booger
Dam...didnt see that thread . Sorry to hear it .Hope they get every thing back together right .Let us know...Bill
liqalu04
Jan 2, 2022 12:58 PM
05UltraYellow
Sep 24, 2015 05:41 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
