Car runing great (UR TT) - **Warning 56k** HI-RES PICS
Old Sep 27, 2004 | 06:43 AM
aalzuhair's Avatar
aalzuhair
Originally posted by ihatethatbobbarker
i really like that exhaust
The quality of the exhaust is very nice and it really sound "just right" not too much and not too soft. When you hit the throttle the sound really draws attention and then when the wastegates open ........ man that’s a totally different story
Old Sep 27, 2004 | 06:47 AM
aalzuhair's Avatar
aalzuhair
Originally posted by PhoenixINX
Wow...
That sir is a sleeper. Kudos to you!
Thanks All I need now is bigger wheels in the back to hold the car down a bit
Old Sep 28, 2004 | 02:48 AM
nitrous350's Avatar
nitrous350
Originally posted by aalzuhair
Thanks man
Well all I did is I hooked the LM-1 with my in car pc and you can get that cool screen. Check this thread it has all the parts for the PC listed.
Thank's Man
I mean where di you get all the signal .. (EGT , BOOST , A/F ...)
from the ECU or E-manage ????
cause i had a LM-1 & laptop
but my laptop does not display others ??????
thank you
Old Sep 28, 2004 | 04:21 AM
aalzuhair's Avatar
aalzuhair
Ok got you of course you must have the Aux. Input Cable #2 (RPM Converter) so you can log all of that.
AFR:
I'm getting that from the sensor
RPM:
I hooked the wire coming from the e-manage RPM to the AUX
TPS:
Gray wire from the e-manage. And you can get the volts reading from the e-manange parameters settings
Boost:
I get that from the white wire from the GReddy pressure sensor.
The volts range from 0v - 5v
0 volts = -24psi
5 volts = +56psi
IAT:
ECU pin # 34 (volts between 0v - 4.8v)
ECT:
ECU pin # 73 (volts between 0v - 4.8v)
The last two I'm still working out what does that translate to in degrees, but the way it is a good gauge, like any other temp gauge.
Old Sep 28, 2004 | 09:44 PM
AmyCroft's Avatar
AmyCroft
Smile Thank You
aalzuhair
Thank You - we were just looking for this information tonight..
Wld350Z - has Greddy TT and E-Manage..
The information you posted will be send to Tony ( Wld350Z )
Thank You my friend...
Keep us posted on any issues we should keep an eye on..
Cheers Amy -
SonnyWu
Nov 24, 2015 08:19 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
35th4me
Sep 13, 2015 05:14 PM
h8redlights
Sep 11, 2015 07:57 PM
