Unorthodox Pulleys w/ vortech?
Old Oct 26, 2004 | 06:14 PM
aron's Avatar
aron
Default Unorthodox Pulleys w/ vortech?
Would it be OK to get the complete unorthodox pulley set with the vortech kit......should i expect bigger gains since SC is ialready there or just claimed gains?
Old Oct 26, 2004 | 06:26 PM
booger's Avatar
booger
I dont think you can use it . Im sure you cant use the crank pulley....its smaller and you will make less boost with it
Old Oct 27, 2004 | 12:57 AM
Barzten1's Avatar
Barzten1
I was told not recommended to use pullies with the Vortech. Booger knows his **** when it comes to Vortech so i always take heed to his advice
Old Oct 27, 2004 | 05:38 AM
mcduck's Avatar
mcduck
You should not use the crank pulley. The crank pulley, as booger says, will result in lower boost.
I kept the other two (non-crank) pulleys, tho, and have had not problems with the set up.
Old Oct 27, 2004 | 07:05 AM
booger's Avatar
booger
Thanks for the kodo's but I dont know poop...I only know what has happened to me with the system and the advice others have given me...Bill
Old Oct 27, 2004 | 08:55 AM
zachcrosen's Avatar
zachcrosen
I realize this is a little off topic, but could you run a crank pulley with a turbo like the Turbonetics system that is coming out in the coming weeks?? I have my eye on both of these and dont want to waste $$ on the pulley if it will negate boost with the turbo. I wouldnt think it would negate boost as the turbo is not belt driven.
Zach
Old Oct 27, 2004 | 08:57 AM
booger's Avatar
booger
I think there would be no problem running the pulley with turbo's
Old Oct 27, 2004 | 09:16 AM
was wesman's Avatar
was wesman
No with the SC because it is belt driven off of the crank, it's fine with the turbo as they are exhaust driven.
You should see larger gains than a NA Z would with the pulleys on a turboed car.
--wes
Old Oct 27, 2004 | 12:50 PM
zachcrosen's Avatar
zachcrosen
--wes
Thanks, thats what I was thinking.
Old Oct 27, 2004 | 01:33 PM
zbicklin's Avatar
zbicklin
Default Re: Unorthodox Pulleys w/ vortech?
Aaron,
I just sold my crank pulley and belts because I read that the smaller circumfrence reduces the boost. I kept the other two for looks and I didn't feel like taking them off.
How's your engine bay looking? A little paint can really make a difference eh?
Steve
Old Oct 27, 2004 | 03:27 PM
aron's Avatar
aron
Steve,
The engine bay looks awesome, really happy i went through it.
Aaron
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
Mrbig
May 29, 2005 10:15 PM
tommy81569
Jun 8, 2004 11:06 AM
