Vortech Custom ideas, need input and answers
Old Nov 3, 2004 | 01:38 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
Default Vortech Custom ideas, need input and answers
Ok guys, it might be time for me to give into FI. I'm looking at the vortech kit, even though I like the HKS more, it's a money issue at the present time. A few things im considering:
1)custom powdercoating the charger housing and piping to match my color scheme
(would it be better to go with the polished or the satin finishes? Which would be better to powdercoat?)
2)using an HKS BOV instead of the vortech (nothing wrong with the vortech, I just like the HKS better)
Also, i am very curious to see if anyone has found solutions to some of the issues that plague the vortech kits. I'm mainly concerned about the belt noise, the rattling noise (sounds like a spray paint can), and timing control module faults. Anyone have any input on these?
I'm pretty curious to see what you guys have to say about some of this.
Thanks!
Old Nov 3, 2004 | 01:39 PM
Tony@Performance
Oh, also, do you vortech guys have issues with buring oil etc...?
what other problems do you vortech guys have?
Old Nov 3, 2004 | 01:57 PM
JimRHIT's Avatar
JimRHIT
If $$ is a big concern .. why are you powdercoating the blower .. and buying a new BOV ...
ask this in the FI section .. youll get more responses
Old Nov 3, 2004 | 11:13 PM
Tony@Performance
my friend does powdercoating, so it's no cost to me.
Old Nov 4, 2004 | 05:11 AM
350zSpeedRacer's Avatar
350zSpeedRacer
The polished finish is more expensive, so if you're going to powdercoat anyway, go with the satin. When I bought my kit, the piping and I/C had already been coated black and it looks good.
If you want to fix the belt noise, don't use the one that comes with the kit. I've gone through 3 that just never stopped stretching and finally switched to a Gates 93 inch belt. Once it's adjusted after the initial stretch, I haven't had a single problem with it since.
I haven't had any rattling noise and like any other kit, you need a good, slightly safe tune to make it run well. If you're having someone do the tuning for you, make sure they're experienced.
BTW, thread moved.
Old Nov 4, 2004 | 10:18 AM
booger's Avatar
booger
Any SC is going to make some noise . The Vortech I believe is the Quietest . Its the BOV that is loud . Buy the filter that Vortech has for it and stuff it full of foam from a foam type air filter [ I used a shop vac filter ] The Gates belt is a must . You will like the Vortech over the HKS , for the power and tunability ...Good luck
350Z_Al
Oct 29, 2020 07:44 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
