Questions for Greddy TT
Old Nov 7, 2004 | 05:50 PM
HK$FairladyZ's Avatar
HK$FairladyZ
Default Questions for Greddy TT
I'm losing coolent in my overflow tank. I think that it's burning up or something. Does anyone have this issue? Does anyone over heat?
Also, the idle is very erratic. Is there anyway to fix this?
One last thing, I hear the pipes knocking in the engine bay at idle. does anyone have this problem?
Old Nov 7, 2004 | 05:59 PM
7 eleven's Avatar
7 eleven
Who did the install?
The coolant issue sounds like your cooling system was not completely bleed of air. if your not overheating you can just keep adding coolant, the air will work it self out.
Or when it's cold open the vent in the back coolant hose and fill the system till it comes out there.
Don't have the idle issue. What did you mean by eratic? Does it hunt up and down? stumble?
I know the passanger side charge pipes are a tight fit, where in the engine bay is the sound coming from?
Gary
Old Nov 7, 2004 | 06:25 PM
HK$FairladyZ
My friend and I did the install.
My car is not over heating. I think that we didn't bleed the air all out of the system. The temp. stays normal even when I drive it hard.
The idling goes up and down between about 750 and 550 constantly. When I come to a stop, the car idles at alittle high and then drops. then it starts to fluxuate.
The sound, I only hear it when I come to a stop. When I'm under the hood, it doesn't make the sound. I think that it might be the passanger intake pipe too. Those two pipes were a bi@*# to put in.
Thanks for the help
Richard
Old Nov 7, 2004 | 06:39 PM
7 eleven's Avatar
7 eleven
The idling issue sounds like a vac leak. Check every joint/flange from the MAF onwards.
If your not over heating just keep adding coolant to the bottle when it's low. It'll stop after awhile.
Look at the pipes for signs of rubbing. It shouldn't make any sounds. If you ignore it it may rub a hole in the pipe. That would suck .
Gary
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
