boost keep goes up.....omfg..
Old Nov 9, 2004 | 12:34 AM
chocoboy81's Avatar
chocoboy81
Default boost keep goes up.....omfg..
i just had test drive with e-01 and the boost keep goes up to 9psi..it was auto mode and it never goes to learning mode....
should be learning at the stock boost which is 6? or 5.5..
but it keeps goes up so couldnt get into learning mode......
what the hell is wrong???
Old Nov 9, 2004 | 12:52 AM
redline tt's Avatar
redline tt
i had a sim prob/the evac line and vac line was wrong..i reran them and now the e01 controls boost..i called greddy had them look at there demo z in showroom to see how they ran wires...i would call them to make sure there c/s and tech dept are really cool.
Old Nov 9, 2004 | 06:50 AM
etx's Avatar
etx
You got the lines on the Boost control solenoid wrong. Check the instructions that came with the e-o1. You most likely have it configured for an internal wastegate. This would let the the pressure through the solenoid and to the top of the ex wastegates, causing your boost to go up. You just need to move one fitting on the solenoid to the other location. RTFM!
Old Nov 9, 2004 | 09:37 PM
chocoboy81's Avatar
chocoboy81
does anyone have pix how you set up the e0-1?????
i changed vac line and boost went up all the way to 12psi at like 5000rpm today.....its getting worse now...need help...
Old Nov 10, 2004 | 06:12 AM
etx's Avatar
etx
Are you flippin helpless? Look, this is right out of your installation maunal! Jeez.
Two things can cause this. A lack of boost to the side of the wastegates, this would raise boost because the wastegate would not have a signal and it would never open. It's like unplugging a lamp from the wall, it does not have any current so it's not gonna light up.
Or, Your getting an EXCESS of pressure to the TOP of the wastegate. This pressure will close the wategate and that's how the e-01 ups the boost. It lets pressure through the solenoid and that pressure closes the wastegate valve.
Old Nov 10, 2004 | 11:41 AM
redline tt's Avatar
redline tt
etx is right once you see the lines and how it is to be set up its pretty easy...
Old Nov 11, 2004 | 10:33 PM
350G's Avatar
350G
Trust me, they're right about the routing of your vacuum lines. We made the same mistake, ran 9psi for a sec, and reworked them . . .
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
