CJM Sleeved / Wicked Block Install has begun...
CJ Motorsports
crank probably weighs.. i dunno.. 45 lb? 55lb?
i am not expecting a precise ammount... I have not tried to see what these turbos have in them... but I would HOPE for 650-700rhwp. maybe more if i put in some nitrous. In the right hands and driven correctly its always controlable... unless my defination differs from yours
CJ Motorsports
the stock block still has the pistons and rods in but there are no currently visable signs of damage. the pistons and rods will go straight in the trash... so if there are no visable signs than I am going to assume they help up just fine. Sure seems like they did.
Mark
www.Quantum-Racing.com
Home of the Dynapack Dyno
CJ Motorsports
QuantumZ: I understand your concerns... but when I said not to worry about the coolant flow I was refering to the sleeves... not the engineering of the factory layout.
To adress your concerns, it would be very easy to increase flow... simply enlarge the pinholes in the headgasket. The head will gladly accept more and even my sleeved block has a much larger opening... its just the headgasket.
Of course if coolant flows too quickly thru the engine it will not absorb as much heat. Also, just because the coolant does flow into the head at that cylinder doesnt mean its not passing by that cylinders combustion chamber... but to address your concerns ill follow around the coolant paths and see how it looks... maybe opening up my headgasket just a hair would be a decent idea. Ill look into it... but to come up with any solid information is next to impossible on something such as this... as you can do is use your best judgement which could be much worse or much better than factory design.
CJ Motorsports
update on the project: today we are overnighting the SGP retainers to Ferrea to have them precisely machine them to fit their valves and 6mm valve locks then they will overnight them back.
Monday I should be back on track.
more coolant flow = more cooling
the heat will be "attracted" to the water, regardless of how fast it is moving.
think of it like wind chill. the air steals the heat from you the faster it blows by you. the coolant will take the heat as fast as you can give it to it
Your theory is not 100% correct.
A lot of modern radiators, mostly european round tube type, have diffusers in the tubes to slow the coolant down to allow better heat exchange.
CJ Motorsports
FINALLY.
We are back in business. Sitting next to me are my cylinder heads and we have them assembled with the entire ferrea valvetrain.
Soon I will be posting pics of installing them to the block and I will go thru the valve lash adjustment process and take some pics and give you guys a description of that.
-Charles
CJM
-Charles
CJM
CJ Motorsports
ahhhhh nevermind.
the head alignment pins are backordered.
nissan parts division is easily the worst ever.
so ill post in a week or two or three or four or whenever i have dowel pins to put the heads on the block.
-Charles
-Charles
ahhhhh nevermind.
-Charles
ahhhhh nevermind.
-Charles
Man....I'm really exicted. I can't wait to read your results and check out the pics. You should have quite the beast when you're all done.
This must be what women feel like when they watch soap operas.
Jeff
Jeff
