FI built motors list
I was wondering if we can start a compilation of the built motors with FI here. This should turn out to be a good resource for others in planning/adjusting their goals.
Motor Internal:
Pauter rods
Arias pistons .020 overbore 8.6:1 compression
ARP headstuds
ARP main studs
stock cams (at the moment)
stock heads
FI:
APS TT
Other:
Koyo Radiator (under consideration)
NISMO low temp thermostate (under consideration)
Clutch Master FX700
Goal:
520 rwhp
600 rwhp (w/ upgraded fuel solution, NISMO LSD)
Motor Internal:
Pauter rods
ARP headstuds
ARP main studs
stock heads
FI:
APS TT
Other:
Clutch Master FX700
Goal:
520 rwhp
Just for clarification, do you want us to post if the build is still pending? Or only if the build is complete. Either way...looks like a good thread. Lots of us have the parts, but are still scheduling the labor.
Internals:
Arias forged pistons, .020 overbore, 9.0:1 compression
Pauter rods
Fully ported and polished heads/lower manifold, gasket matched
Tomei 264 cams
Fully balanced bottom end
ARP head/main studs
FI System:
APS turbo kit
Engine Management:
HKS F-con planned
Pauter rods
Tomei 264 cams
ARP head/main studs
FI System:
APS turbo kit
Engine Management:
HKS F-con planned
Motor Internal:
Pauter rods
Arias pistons 8.5:1 stock bore
AEBS Sleeves
ARP headstuds
ARP main studs
JWT 260 cams
CJM Race Heads
Ferrea entire valvetrain - oversize valves
FI:
Greddy TT
Other:
Everything
Goal:
500rwhp 93 octane (EASY) good for 100 more.
600rwhp 100 octane (EASY)
700rwhp C16
800rwhp C16/No2
Engine Management:
HKS F-CON V-Pro (first known US 350z running this system since 9/3/04
100% custom fuel system utilizing AAM fuel rails. Soon a replacement for intank pumps.
Pauter rods
AEBS Sleeves
ARP headstuds
ARP main studs
JWT 260 cams
CJM Race Heads
FI:
Greddy TT
Other:
Everything
Goal:
700rwhp C16
800rwhp C16/No2
Engine Management:
Motor Internal:
Pauter rods
Arias pistons: 9.3:1 (.020" overebore)
ARP head & main studs
stock cams/valves
radial valve job
heads (optimized)
shimmed springs
FI:
PE TT
- water cooling connected
- actuator springs upgraded (0.5 bar baseline boost)
Other:
Radiator (planned)
HKS EVC V boost controller
Innovate Motorsports Full Logging
in-car PC (for virtual on-screen gauges)
dual bank A/f measurements (at least for the initial tuning)
Goal:
530 rwhp (91 CA pump gas)
580 rwhp (on 100+ gas)
more with upgaded fuel system
Engine Management:
TS reflash + J&S Safeguard (for now)
Unichip or AEM EMS in the future (possibly)
Pauter rods
stock cams/valves
radial valve job
heads (optimized)
shimmed springs
FI:
PE TT
Other:
Radiator (planned)
Goal:
Engine Management:
For my 2003 G35C, longblock in process , I don't expect TT intall until ~April 2005.
Motor Internal:
-Pauter rods
-Arias pistons .020 overbore "custom dish" 9:1 compression
(PM skirt and and Ceramic coated dishes)
-ARP headstuds
-ARP main studs
-JWT S1 Cams nad spring
- SGP Titaniium retainers
- Mild port and polish
FI :
APS TT for G35, Thermal Barrier coating on manis, impeller housings and downpipes.
APS Plenum and Big Fuel system (under consideration)
TB coat both bottom and top Plenum
Stillen bumper for FMIC airflow
Other:
UR pulleys (already)
Borla TD (already)
Crawford CATs (already), may change out to Test Pipes.
NISMO low temp (for sure)
RPS twin carbon (under consideration)
Cusco RS LSD (for sure)
J&S safeguard (under consideration)
Aquamist Water Injection (under consideration)
Koyo Radiator modified for G (under consideration)
Goal:
>500 rwhp on crappy Ca. 91 , may require Water Injection
>600 rwhp on 100 .
Motor Internal:
-Pauter rods
-ARP headstuds
-ARP main studs
FI :
Other:
Borla TD (already)
Goal:
>600 rwhp on 100 .
Motor Internals
Arias Pistons .020 over 8.6 comp
Pauter Rods
ARP Head studs and Main.
JWT Springs
SGP Retainers (?)
Stock Cam
Stock Head
FI and Extras listed in sig.
Goal: 550rwhp on 18 psi 93 octane pump gas
Pauter Rods
JWT Springs
SGP Retainers (?)
Stock Cam
Stock Head
Motor Internals:
Pauter Forged Rods
Araias 9.0:1 forged pistons
Port Matched heads
ARP Head and Main Studs (From SGP)
Balanced/Blueprinted
FI:
Greddy Twin Turbo Kit with FMIC
Profec e-01
Greddy eManage
Other:
AAM return fuel system
Walbro 255
550cc Injectors (coming soon)
Crawford Plenum
Greddy Evo2 Exhuast
Test Pipes
Goal:
550whp everday driver on 93octant
600whp maximum WHP
17-20psi of boost
Pauter Forged Rods
Port Matched heads
FI:
Profec e-01
Greddy eManage
Other:
Walbro 255
Crawford Plenum
Greddy Evo2 Exhuast
Test Pipes
Goal:
600whp maximum WHP
17-20psi of boost
Originally posted by dansouliere
Wow.. Your brave
Wow.. Your brave
one max (Hal) is putting down 531.2Hp 603.1lbs/tq on stock internals. But you know what it could not even be that the motor is not strong enough, it is all in the tunning. And don't get me wrong i love VQ35s
Rods: Pauter
Pistons: CP 8.5:1 compression stock bore
Rod bearings:OEM
Main bearings:OEM
Headgaskets:OEM
Fuel: Altered Atmosphere,may upgrade to APS
Radiator:KOYO
Thermostat:NISMO
Roll cage:Kirk Racing
Heads:stock ( its not needed for my goals to touch the heads)
Cams:Stock
Clutch:Clutchmasters stage 3 , may upgrade eventually to stage 4
Flywheel:OEM
Rear:OEM
Turbo:APS BABY!!!
Plenum:APS BABY!!
Brakes:Racing Brake Big Brake Kit
Goals:500-550whp 94 octane daily driven..
Rod bearings:OEM
Main bearings:OEM
Headgaskets:OEM
Radiator:KOYO
Thermostat:NISMO
Cams:Stock
Flywheel:OEM
Rear:OEM
Turbo:APS BABY!!!
Plenum:APS BABY!!
