FI built motors list
Old Nov 23, 2004 | 11:04 AM
  #41
Enron Exec's Avatar
Enron Exec
Default Re: FI built motors list
Update
Originally posted by Enron Exec
I was wondering if we can start a compilation of the built motors with FI here. This should turn out to be a good resource for others in planning/adjusting their goals.
Motor Internal:
Pauter rods
Arias pistons .020 overbore 8.6:1 compression
ARP headstuds
ARP main studs
stock cams (at the moment)
stock heads
FI:
APS TT
Other:
Koyo Radiator (under consideration)
NISMO low temp thermostate (under consideration)
Clutch Master FX700
Goal:
520 rwhp
600 rwhp (w/ upgraded fuel solution, NISMO LSD)
Motor Internal:
Pauter rods
ARP headstuds
ARP main studs
Mild port and polich, 5 angle valve job
FI:
APS TT
Other:
Koyo Radiator
ATS twin disk 1350kg pressure plate
Goal:
520 rwhp
Old Nov 23, 2004 | 12:37 PM
  #42
ZxRage's Avatar
ZxRage
Turbo:
APS Twin Turbo, w/Jet Hot coating
Internals:
Pauter Rods
CP Pistons 8.5:1 (possibly coating side skirts)
ARP Head and Main studs
(possibly: sleeving engine, not sure yet)
Heads:
Port and Polish Heads
Ferrea Valvetrain kit oversized 1mm
(eventually: Tomei or JWT 264 Cams)
Fuel:
Altered Atmosphere upgraded fuel kit
(eventually: APS Tall boy Plenum with upgraded fuel kit)
Cooling:Koyo Radiator and Nismo Thermostat
Clutch/Flywheel:
ATS Carbon/Carbon or RPS Carbon/Carbon or Exedy Triple Carbon
LSD:ATS Carbon Differential
Rear Drive:Stock 5AT Pumpkin
There is more that I probably left out but I think this gives you an idea. My goal is to be able to pull 10 second 1/4 miles and get up to at least 750 rwhp.
